runk
Reg: 05-27-12
05-27-12 03:37 PM - Post#2230446
Hey, does anybody know how to install dash trim? I need to know how to remove the ring around the headlight knob and around cigarette lighter ring? To put my new insert in, the rest I have no problems with..
This
Forum is Sponsored by
05-27-12 04:10 PM - Post#2230452
In response to runk
Welcome.
What year model? There is a button on the headlight switch that has to be pushed in to pull the knob and shaft (one piece) out. Then the spanner type nut can be unscrewed to remove the bezel. The button is on the top of a 55/56 switch and onthe bottom of a 57 switch. The cigrette lighter has a cover that unscrews off the back of the lighter houseing. Disconnect battery first. Link to lighter.
Picture showing button and knob and shaft.
57 2dr HT (restoring)
Edited by acardon on 05-27-12 04:18 PM. Reason for edit: No reason given.
runk
Reg: 05-27-12
05-27-12 04:48 PM - Post#2230472
In response to acardon
Thanks for the information on the headlight switch, however how about the ring on the cigarette lighter? Any Tricks I should know about?
It's a 1956 210 Chevy, but I'm adding the bel Air trim.
Thanks for the help .
05-27-12 07:16 PM - Post#2230539
In response to runk
The ring is part of the houseing assy. The cigrette lighter houseing is held in by the retainer in the link I posted. The retainer is screwed to the houseing on the back of the dash.
runk
Reg: 05-27-12
05-27-12 07:31 PM - Post#2230545
Thank you very much for the help, I think you have really helped me with my problem, i'm going to try it tomorrow.
Thanks Again,
62chevy427
Loc: laurens sc
Reg: 04-13-06
05-28-12 07:07 AM - Post#2230686
In response to runk
i always remove the radio and clock/speaker and the speedometer too because the trim is held in place by them. makes it easier for me. i put some masking tape to hold the new trim in place while installing all the switches,speedo,etc. on the last one i did,the outside corners of the two short end pieces where the screws are were not made correctly and i had to rework them slightly for a better fit and to keep from scratching the paint.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
11 malibu (new) |
2dr150
Loc: eastern S. C.
Reg: 07-16-06
05-28-12 10:19 AM - Post#2230751
In response to 62chevy427
Klaus, You are absolutely correct when you say the ends of the two short pieces are not made correctly. I bought a set from East Coast that are made by Gene Smith and the ends were terrible. East Coast suggested I grind the ends down. I hate to start grinding on a piece of aluminum that I paid $125. for. I have my old pieces on for now. Were you working on 55-56 pieces or 57 pieces? How did the grinding turn out? Tom
1950 deluxe coupe
1966 chevelle, ss396
1957 2dr 150,owned 6 yrs
1933 master 5 window coupe (sold),my chevys |
Edited by 2dr150 on 05-28-12 10:20 AM. Reason for edit: No reason given.
This
