Dean50
Loc: Michigan
Reg: 01-02-07
05-27-12 02:32 PM - Post#2230411
To remove the fender shield (gravel guard) remove the "loading hole cover". What the heck is that? I'm not near the car right now and I just can't picture anything under the fender like that.
http://chevy.oldcarmanualproject.com/fisher/1949/4...
This
Forum is Sponsored by
brewsterg6
Loc: Bolton Ontario, Canada
Reg: 10-31-08
05-27-12 04:48 PM - Post#2230471
In response to Dean50
Dean... the page you posted there is for a convertible. Is that what you are working on? It sounds like something from the interior, possibly from behind the seat? Do you have the seat and interior panels out?
1951 2dr Sedan... In the family since new!
1950 Convertible |
Coaldalecar
Loc: High River, Alberta, Cana...
Reg: 10-10-08
05-27-12 05:57 PM - Post#2230501
On my 52 2dr sedan they are accessed from inside after the side panel is removed. Hope this helps.
Alan Klassen, High River, Alberta, Canada
1952 Chev 2Dr Sedan Deluxe, 99 Olds Alero, 02 Chev Silverado Ext Cab |
dsacton
Loc: Boulder, CO
Reg: 11-01-11
05-27-12 08:02 PM - Post#2230562
Hi Dean50,
I suspect that this has to do with the need for interior access. Is this a 2-door? Then that has to be it. I have a 2-door 54.
I want to add that, upon reading your post, I did a Google search on "loading hole cover." Even though only a few hours had passed, what came up in the search was YOUR POST!. Big Brother is watching...
Scott A.
05-27-12 08:36 PM - Post#2230580
In response to dsacton
I had to take out my back seat and the side panel to get to the nuts that held on my gravel guards on my 54. I have pics if you want to see them?
| Bob Hayden's 54 Chevy, 350 Engine with TH400 Tranny and 94 4X4 Blazer Rear End with 3:23 gears.(FINISHED PICS) </a> My 54 Albums |
05-27-12 08:39 PM - Post#2230583
In response to Bob_Hayden
Sorry!! I lied! No pics. Thought you could see them in the pics I took of the drain tubes but you can't.
50sChevys
Loc: Central Texas
Reg: 03-23-02
05-27-12 08:49 PM - Post#2230590
That's what you have to do to get to those gravel guard nuts which hold them on.
old51sedan
Loc: Michigan & Florida
Reg: 10-11-09
05-28-12 04:28 AM - Post#2230624
Dean
Yes, you need to get ascess from inside the car below the rear window. there should also be a phillips screw on the outside down along the bottom. Did you dent one that you need to replace or wanting to have them polished?
1951 styleline 2dr deluxe
Original 51 plate, Dealer Tag, Documents
58,000 original miles, second owner
1954 PG 235, rear axle, Power Steering
Fenton Headers With Smitys |
Dean50
Loc: Michigan
Reg: 01-02-07
05-28-12 06:14 AM - Post#2230661
In response to old51sedan
Hi Donn and thanks everyone!
Two door sedan.
Yes, I have two fresh shields and one of mine has a couple of scratches in it. I'll pull the back seat and check it out. I'll also change out a piece of dented door trim while I'm at it.
Thanks, all.
kensluys
Loc: Bellingham, WA, USA
Reg: 04-18-01
05-28-12 12:30 PM - Post#2230794
I thought the loading hole was the plate where the window regulator and other mechanisms related to the rear quarter window were put in. Shown below the regulator in this page (81) from the same manual:
But I didn't think any of the gravel guard bolts were accessible from there. As mentioned by others, I had to take out the rear seat to get to the bolts on my 1951.
| 1951 BelAir - Bought it in 1969, sold it in 1970, found it and bought it again in 1999. |
Dean50
Loc: Michigan
Reg: 01-02-07
05-29-12 01:19 PM - Post#2231210
In response to kensluys
Thanks again.
I didn't notice I had shown the convertible trim parts above but the gravel shield looks about the same as mine. Once I get the seat out I should be able to figure it out.
This
