tarps (7)
Username Post: HEI help        (Topic#281691)
georgiaboy5
Reg: 05-27-12
05-27-12 08:05 AM - Post#2230281
Running a stock type msd hei distributor in a dirt track stock car. The problem is with the engine setback my cap is hitting the firewall. The part that sticks out for the wire connections is pointing almost straight back. My question is, can the distributor be taken out and turned 180 degrees? That would give me extra clearance. Any help would be greatly appreciated
IgnitionMan
Reg: 04-15-05
05-27-12 09:17 AM - Post#2230316
    In response to georgiaboy5
Distributor can be "oriented" in the engine any way you wish to install it, but, you MUST make the rotor point to the number 1 terminal on the cap, no matter which terminal you use, and, the firing order must be maintained correct.
Other than those two factors, anything goes.
georgiaboy5
Reg: 05-27-12
05-27-12 01:09 PM - Post#2230391
    In response to IgnitionMan
If its not too much trouble, could you please give me a step by step process of how to get this done. Kinda new to this. thanks again
C10 Sleeper
C10 Sleeper
Loc: Redding Ca
Reg: 03-17-09
05-27-12 02:00 PM - Post#2230403
The rotor only fits on one way so as as long as #1 piston is the tdc of the compression stroke you should be good to make #1 on the cap wherever you want. After you find tdc pull the dist up enough to clear the cam gear and rotate. Just remember once it starts to go back down the shaft will rotate about anther 1/4 turn. You will need a long flat head screwthat driver to align the oil pump shaft. Then just follow the firing order in a clock wise rotation for the plug wires.
http://photobucket.com/C10Pictures
georgiaboy5
Reg: 05-27-12
05-27-12 04:19 PM - Post#2230454
    In response to C10 Sleeper
Ok, i think i got it. Get number one piston to TDC. Pull distributor and set back down where i want cap to point. Wherever rotor points will be new number one on cap. Reinstall wires per firing order going clockwise. Does that sound right?
C10 Sleeper
C10 Sleeper
Loc: Redding Ca
Reg: 03-17-09
05-27-12 04:34 PM - Post#2230463
Thats how I would go about it.
georgiaboy5
Reg: 05-27-12
05-27-12 07:00 PM - Post#2230533
ok thanks for the help
IgnitionMan
Reg: 04-15-05
05-27-12 08:24 PM - Post#2230572
One very important factor, make sure the number 1 piston is at top dead center (TDC), on the COMPRESSION STROKE, NOT ON OVERLAP.
Pull the number 1 spark plug out of the engine, and crank the engine over with the ignition disabled, finger/thumb over the spark plug hole in the head, so you can feel pressure, when you start to feel pressure, then go to the next TDC on the dampener.
In a Chevy engine, there are TWO TDC's, one is when the engine has made compression, the other, no pressure, overlap cycle. You want to set number 1 on the distributor to compression on cylinder number 1, NOT overlap.
models916
Loc: Addison, IL
Reg: 05-28-10
05-28-12 05:34 AM - Post#2230652
You don't need to pull the distributor. Just rotate the cap to where you want it and move the wires so that #1 is where the rotor is when at TDC on #1 cylinder. Make sure you are on compression on #1 cylinder. The engine does't care where the rotor is pointing as long as the rotor is pointing to the correct plug and the #1 cylinder is at compression.
IgnitionMan
Reg: 04-15-05
05-28-12 08:14 AM - Post#2230715
    In response to models916
Yup, all that's what I already said.
georgiaboy5
Reg: 05-27-12
05-28-12 03:11 PM - Post#2230830
it looks like i will have to pull distributor, cap only fits one way
05-28-12 03:48 PM - Post#2230848
You don't need to, you can turn the distributor AND cap to where you want the power wires to be. Then relocate the plug wires on the cap.
Here's the procedure.
Locate #1 plug wire on the cap and mark it's location on the manifold or some other reference point around the distributor. If you rotate the distributor in exactly multiples of 8, timing will be real close when your done.
Turn the distributor to where the power and tach wires are where you want them.
Pull all the wires off the cap and put #1 wire at the location that #1 used to on, followed by the rest of the firing order.
Reset timing with a light.
57 2dr HT (restoring)
georgiaboy5
Reg: 05-27-12
05-28-12 05:05 PM - Post#2230873
    In response to acardon
Do i do this with number 1 at TDC? Just turn distributor and move number 1 wire position on the cap? Sorry
05-28-12 05:23 PM - Post#2230884
Just turn and put #1 to the same location it used to be.
busterrm
busterrm
Loc: Wichita Falls, Tx
Reg: 08-31-10
05-28-12 06:46 PM - Post#2230918
Yup! I agree with Iman, make sure #1 is on compression stroke, you can also pull valve cover and watch both valves open and close intake last then rotate until you feel pressure in plug hole then go to TDC and drop the distributor.
Again, I agree with Iman, you can put number 1 where you want it but make sure you wire the firing order from where you place # 1 and you'll be good to go.
==== BOB ====
If I can't smoke the tires I want more!
1976 Chevy Nova
2007 Chevy 1500 1/2 ton
2005 Yamaha Vstar 1100 midnight custom
Edited by busterrm on 05-28-12 06:50 PM. Reason for edit: No reason given.
models916
Loc: Addison, IL
Reg: 05-28-10
05-29-12 05:45 AM - Post#2231023
Now do you see why I said it all again?
05-29-12 06:42 AM - Post#2231044
If you don't pull the distributor, why are you turning the engine to #1? The rotor isn't going to move when you turn the distributor. It won't matter if it's pointing to #5, # 3, or halfway between any 2 wires. If #1 wire is, "say" at 7 oclock position, turn the distributor an equal # of positions till another terminal is at 7 oclock position and the power wire is where you want it. Plug #1 wire back in the 7 oclock position, followed by the firing order and crank the engine up.
IgnitionMan
Reg: 04-15-05
05-29-12 09:32 AM - Post#2231101
Please be aware that there is a vacuum advance on that distributor, and possibly, it cannot simply "just be rotated a half turn" and re-firing ordered.
You could rotate the dist TWO plug wire terminals worth, then move the plug wires two terminals each, that might you close to what you are after.
Just have to work with it.
C10 Sleeper
C10 Sleeper
Loc: Redding Ca
Reg: 03-17-09
05-29-12 11:51 AM - Post#2231171
Good point about the vacuum advance. Not to mention the original poster mentioned limited firewall clearance due to engine set back. I have been in similar situations when I was playing the circle track game years ago. That is why I recommended pulling the distributor out.
Ignitionman: Its good to see you back.
georgiaboy5
Reg: 05-27-12
05-29-12 04:10 PM - Post#2231259
Hey guys its an MSD pn 8365. No vac adv. The wire connector part that "sticks" out is pointing straight back to the firewall. I would like to turn the dist 90 degrees clockwise as looking at the dist from the front of car, to where the connector part is towards the drivers side of car. I thought i had it figured out, but im getting all confused again. Ive had the timing screwed up before, just trying to avoid another nightmare. If its an easier process to go 180 degrees, i can do that. Thanks for all the help
IgnitionMan
Reg: 04-15-05
05-29-12 09:11 PM - Post#2231346
No vacuum advance, no problem, just put it where you want, confirm TDC and rotor position, set the firing order, time it, and...go.
I'm not back, just visiting until our ultra useless board pest gets wind of my posts, and flames me over and over again.
Besides, this fellow needs the help.
Matt
Matt
Loc: SAV
Reg: 09-26-01
05-30-12 01:43 PM - Post#2231541
Did you really have to say something inflammatory like that? Maybe there's a reason why it has happened in the past.
Yes, and we more than welcome your insight and feedback. You know way more than I do here, that's for sure. Thanks for your posts.
models916
Loc: Addison, IL
Reg: 05-28-10
05-31-12 05:47 AM - Post#2231762
Pull the wires off the cap, rotate the distributor so the cap is where you want it and then replace the wires so that #1 is where the rotor is when #1 cylinder is at TDC compression and follow the rest in order. Why pull the distributor?
IgnitionMan
Reg: 04-15-05
05-31-12 07:07 AM - Post#2231781
Yup, that's what I said above, again.
georgiaboy5
Reg: 05-27-12
05-31-12 09:24 AM - Post#2231823
Thank you guys. I think I finally got it.
georgiaboy5
Reg: 05-27-12
05-31-12 09:26 AM - Post#2231824
Thanks for all the help ignition man!
IgnitionMan
Reg: 04-15-05
05-31-12 03:58 PM - Post#2231939
Actually, it was, and is my pleasure. Hope you get it dialed so it works for you. Great group here, they have a lot of saavy with these issues.
Execution time: 0.066 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:23 AM
