350mrh
Reg: 03-07-05
05-26-12 09:58 PM - Post#2230211
I need to change out my steering column on my 69 and I have one from a 77. So basically going from non power steering to power steering. Does anyone have any suggestions or advice? I appreciate any input. Thanks.
JimKshortstep4x4
Chevytalk Moderator & "9th Year" Silver Supporting Member
Loc: Muskegon, MI, USA
05-27-12 02:24 AM - Post#2230227
In response to 350mrh
The 77 will require some mods as it is larger. Is there a need for changing out the column as the 69 column can be be mated to the 77 gear box easily?
Member 65-66 Full Size Chevrolet Club
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
71 Short bed stepside 4x4, 350/350
Current project, 72 GMC Shortbed, stepside, 427 |
350mrh
Reg: 03-07-05
05-28-12 08:49 PM - Post#2230945
Jim,
Thank you for your input. I was wondering about that. So it is possible to leave the original column and mate it with the power steering box from the 77. Do you know if any mods are needed to the frame or goes it just bolt right on?
Edited by 350mrh on 05-28-12 08:50 PM. Reason for edit: No reason given.
JimKshortstep4x4
05-29-12 01:45 AM - Post#2230997
The steering box will bolt in and work correctly. The lines will fit, also.
