Username Post: turn signal help        (Topic#281585)
xstuntman
Loc: west Texas
Reg: 04-13-09
05-24-12 07:21 PM - Post#2229464
I pulled the turn signal guts out today and while removing the copper circuit that the hazard switch screws into it came apart.
So seperate from it is another black plastic piece in the same general shape with a black tab on it. I have no clue where it goes but im sure it keeps something from touching something. Anyone know how it works or have pictures that would be close to an '85?
chengny
Reg: 01-15-12
05-25-12 03:24 PM - Post#2229748
    In response to xstuntman
Do these help?:
Or this:
Edited by chengny on 05-25-12 03:48 PM. Reason for edit: No reason given.
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
05-25-12 09:21 PM - Post#2229854
    In response to chengny
You can replace the entire assembly. You can get it from the parts store.
The plastic part of the switch tends to wear out and break, causing the switch to stop self-cancelling. Only cure is to replace it.
Execution time: 0.08 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:59 AM
