jwsmo
Loc: N St Paul Minn
Reg: 05-20-08
05-24-12 07:06 PM - Post#2229460
Hi Guys, It's been awhile since I've visited last time. I have just found a leak on my tranny. I have a 54 with a 55 PG. And it seems to be leaking at the speedometer connection. Last time I drove it, a day later I noticed a good size puddle under the car. The tranny only has 1000 miles on it and the cable is new. Any ideas?
Thanks for your help. It's good to be back
This
Forum is Sponsored by
dsacton
Loc: Boulder, CO
Reg: 11-01-11
05-26-12 04:59 PM - Post#2230124
In response to jwsmo
Hi Jim,
I figured some of the smarter folks would have replied by now. I will add that my car has been parked for about 2 months now, while I work on the body. I noticed what must be about 1 quart of ATF on the floor of my garage, but it was all coming out of the rear seal on the drive shaft. I tightened it by hand, and it cleaned it up.
Are you certain that it is leaking out of the speedometer cable? Once that is tightened, there really is nowhere for it to leak. Is it possible that it is leaking elsewhere and running to the cable?
My tranny still has small leaks everywhere, but then it has 160,000 miles and 58 years on it. I could be wrong, but I think these trannyies just leak by nature. Good luck,
Scott A.
54 Bel Air
2blu52
Reg: 03-12-02
05-27-12 06:41 AM - Post#2230265
I do not know if it applies but the early PG transmissions had a habit of burping transmission fluid after sitting for lengthy periods. A friend has a 57 which has a valve installed to stop this. Search the archives for more accurate information on this.
THOMAS JEFFERSON |
dsacton
Loc: Boulder, CO
Reg: 11-01-11
05-27-12 12:38 PM - Post#2230383
In response to 2blu52
Ditto on that! Last night, litterally minutes after my last post, I looked under my car (that has been sitting for 2 months) and it was SPEWING ATF out of the fill spout. It was like it had been overfilled. Then, after starting it and driving for about 1 mile, I checked it and it is a quart low. No more burping. Weird!
Scott A.
2blu52
Reg: 03-12-02
05-27-12 02:46 PM - Post#2230423
In response to dsacton
I do not have a PG transmission but have read other posts and information on this and from what I understand it has to do with a drain down situation over filling a portion of the transmission. Gene Schneider has checked in on this kind of post before and that is what I absorbed from his post. The archives should have several different posts on the subject.
THOMAS JEFFERSON |
dsacton
Loc: Boulder, CO
Reg: 11-01-11
05-27-12 04:57 PM - Post#2230480
Thanks. Do you mean that the tranny was overfilled?
I've always wondered, because the lid on the dip stick is loose, and can slide up and down about an inch. I'm not 100% sure if I'm adding an extra "inch" of fluid or not.
Scott
2blu52
Reg: 03-12-02
05-27-12 06:04 PM - Post#2230506
Scott
No the fluid level running is where it is supposed to be, it is a matter of drain down from one place in the transmission to the lower end. Wish I could be more specific but being a 3spd person I do not save PG stuff.
THOMAS JEFFERSON |
dsacton
Loc: Boulder, CO
Reg: 11-01-11
05-27-12 07:58 PM - Post#2230558
Thanks.
I should add the the front end of the car was about 8 inches higher than the rear. Maybe this is why it "burped" so bad.
Scott A.
This
