LARRY_56
Loc: BEACH PARK IL. USA
Reg: 11-05-01
05-23-12 06:49 PM - Post#2229115
I picked up a car from Florida and is it ever loaded with brown spots on the windows! It must be from the very hard water there. Any tried and true ideas on how to remove them?
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
05-23-12 07:08 PM - Post#2229123
In response to LARRY_56
try I think it was called bon ami, my dad used to use it on his glass all the time. Of course that is if it's not the glue in between the layers discolored or delaminating.
Kdurgin
Loc: Maine
Reg: 10-28-07
05-23-12 07:42 PM - Post#2229142
In response to turbo38s10
The Bon Ami is also used to clean the newer glass oven burners.
62 Impala SS 383 Small Block, Tremec TKO 600, 3.70 gears. Black.
2011 Corvette Grand Sport dry sump 6 speed 436 H.P 2LT. Black.
1965 C-10 SWB BBW Fleetside Black.
2003 100th Anniversary Harley 2 tone Silver and Black Road King.
Mad Joe
Loc: Wichita Falls, Tx.
Reg: 05-09-07
05-23-12 08:24 PM - Post#2229155
Might try white distilled vinegar to see if it cuts it.
motorman
Loc: south western pa.
Reg: 01-25-00
05-23-12 09:52 PM - Post#2229175
some people use brass wool. do NOT use steel wool
| retired race engine builder,former NASCAR tech inspector. new corvettes owned 1959,1962,1963,1964,1965, 1966,1997,1999,2002,2005, 2008 plus 30+ other chevy cars and trucks along the way |
junky
Reg: 06-27-10
05-24-12 07:37 AM - Post#2229246
In response to motorman
Be very careful using anything that has an abrasive, or can scratch the glass. I am assuming it is side glass, which is tempered. Usually it takes a special abrasive that is used with a high speed bonnet to remove the spots. I would check with a local auto glass show to see if they can do it for you. If you break the glass, it will cost you a lot more.
Verne_Frantz
Loc: hightstown,NJ USA
Reg: 08-22-00
05-24-12 02:09 PM - Post#2229362
I've tried the vinegar trick and it usually works well except it can take a lot of rubbing. The vinegar takes some time to dissolve the residues.
Eastwood sells a glass polishing kit which uses cerium oxide (the brown powder) mixed with water. It works wonders and will even take out small scratches. I've used cerium oxide to polish scratches out of glass windows on photomultiplier tubes that were sent into outer space so I am familiar with the results.
Do a little research and you might be able to buy it in bulk rather than stepping up to Eastwood's kit.
Verne
Carl1962
Loc: Australia
Reg: 04-01-10
05-24-12 07:59 PM - Post#2229471
In response to Verne_Frantz
There's this stuff called CLR that disolves Calcium, Lime and Rust. You can buy it at home depot
http://www.homedepot.com/buy/cleaning-cleaners -hou...
It does a fantastic job of disolving hard water marks.
05-25-12 10:53 AM - Post#2229687
In response to Carl1962
I would not use CLR on any part of the car. It eats aluminum, and is not to be used on any painted surface (from CLR's website)
cowfarmer350
Reg: 02-03-01
05-25-12 04:55 PM - Post#2229772
Verne
. I used to work in a mirror manufacturing factory , all the glass was rubbed down with cerium oxide before silvering , also was used for polishing out scratchs , glass edges and bevels , we had buckets of it , but that was 30 years ago
