Username Post: 53v54, what's interchangable?        (Topic#281450)
ChrisBorsheim
Loc: Houston, TX
Reg: 05-21-12
05-21-12 06:28 PM - Post#2228381
I recently purchased a '53 210 which is missing a handful of essential parts. What between these years is interchangeable? I'm almost assuming that nearly everything is.
Thanks in advance.
Idaho
Idaho
Loc: Upstate New York
Reg: 03-02-07
05-21-12 06:41 PM - Post#2228384
    In response to ChrisBorsheim
Yes, there's a ton of parts that are interchangable between the two years, but I'd suggest you give us a list of the parts you need and we can advise you from there.
1953 210 Chevy convertible, 1956 Gmc pickup, 1952 MGTD convertible, 1973 HD Superglide, 1972 HD Electraglide, 2002 HD Heritage Softail Springer.
05-21-12 07:11 PM - Post#2228398
    In response to Idaho
Fenders are not switchable. Hood is different due to the location of the emblem holes but can be switched. Trunks are the same for the same model. Splashpan is different Front bumper is very different but rear bumpers are the same. Engines are different but a '54 engine is a great substitute for a '53 stick engine. Tranmissions are the same. Door panels and seat cover styles are different. Glass is the same. Suspension is the same. Radiator is the same. Instruments and gauges are the same.
19IMnuts53
19IMnuts53
Loc: Regina Beach, Sask.
Reg: 09-21-08
05-21-12 07:16 PM - Post#2228402
front fender and hood are interchangeable if you are going to change the complete front clip including the bumper. Other wise you can't change the just the fenders or just the bumper from 53 to 54.
no such word as "Can't" you either don't want to or are to lazy.
DADS53
Loc: Yak. Valley WA
Reg: 09-19-11
05-21-12 07:38 PM - Post#2228411
    In response to 19IMnuts53
I'm no expert but I was just looking at the dash of my '53 stick and its oil pressure gauge only goes up to 30psi since it's engine was a "splash" oiler. Didn't the '53 P.G. and thus all engines up from there have higher oil pressure, thus their gauges went higher?
It's not about the car.
Loc: Ellijay, GA
05-21-12 08:02 PM - Post#2228424
    In response to DADS53
Yes, oil presuure gauge.
05-21-12 08:58 PM - Post#2228449
    In response to bobg1951chevy
'53 PG oil pressure gauges were high pressure just like '54. I believe the turn-signal indicators in '54 dashes were green, while '53's were white... I seem to remember SOME difference in their color, but it's possible the '53's I've seen were just sun-bleached.
If you're going to use '54 fenders you'll need the '54 splash pan and '54 grill in addition to the bumper.
Idaho
Idaho
Reg: 03-02-07
05-21-12 09:51 PM - Post#2228468
You are correct there Robert, the arrows were different colors between the two years.
ChrisBorsheim
Loc: Houston, TX
Reg: 05-21-12
05-21-12 11:29 PM - Post#2228489
That's ultimately what I'm moving towards right now.
The car is missing:
Rear side glass
Interior (dash and thrashed seats remain - no gauges)
Splash pan
Bumpers
Motor
Transmission
Being that it's a incomplete shell I'm debating where to take it as there are a lot of body parts for a '54 available near me which could quickly turn this car around - minus the drive train.
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
05-22-12 02:01 AM - Post#2228501
the complete 54 clip works well.and if you can grab the 54 tail lights for it.there nicer and you can get the bubble red lens for them making car even nicer
Happy Belair
Reg: 10-29-06
05-22-12 05:51 AM - Post#2228540
nope no sun fade. 53 turn signal arrow were white and 54 green................
Hoods and trunks are different as to bexel mounting points.
53 cloth wire
54 plastic.
Tail light pig tails also different.
door handles, convert and hardtop are the same....
the door hanlde retainer will not interchange
Radios are different..
Yeah reallly it would be better if you give a list of what your missing...............I think the guys here can help yo straighten it out from there.
54 Belair 1067DTX, Roman red 327 Turbo350
54 Belair Hardtop, just bod off frame,work in progress
54 210 Station wagon Father in laws pass me down
Happy Belair
Reg: 10-29-06
05-22-12 05:54 AM - Post#2228546
  • ChrisBorsheim Said:
The car is missing:
Rear side glass
Splash pan
Bumpers
Motor
Transmission
Side glass.interchangeable
guages us the 54
splash pan fron or rear? rear interchange able, front you will need the COMPLETE front clip of 54
Motor and transmission, changable
Where you at, you could be close to some of us
cederholm
cederholm
Loc: Brooklyn NY
Reg: 09-28-10
05-22-12 06:34 AM - Post#2228558
    In response to Happy Belair
  • Happy Belair Said:
53 cloth wire
54 plastic.
My '53 wires are plastic.
~ Carl
Carl E. Cederholm
Brooklyn NYC
05-22-12 07:19 AM - Post#2228571
    In response to cederholm
Happy Belair, I had no idea the radios were different. How are they different? And what's the story on the door handle retainers?
Idaho
Idaho
Reg: 03-02-07
05-22-12 10:26 AM - Post#2228618
    In response to arnieg141
Unless I am confused here as to what he is missing, from what I see the only thing he needs to come up with specific to his '53 are the front bumper and the front splash pan. Everything else he needs will swap. Why in the world would he swap an entire front end from a '54 on to his car just to get a splash pan and a front bumper that fits? Other than the motor and trans, he's got a 95%
complete car!
19IMnuts53
19IMnuts53
Reg: 09-21-08
05-22-12 11:47 AM - Post#2228644
cause in order to use the splash pan and bumper from a 54 you need the grill, the 53 grill is different then the 54 if you need the grill you need the fenders that's why the front clip. He didn't say he had another 53 to swap with, he said he had a 54 and wanted to know what he could swap onto the 53. hence the entire front clip
Edited by 19IMnuts53 on 05-22-12 11:49 AM. Reason for edit: No reason given.
ChrisBorsheim
Loc: Houston, TX
Reg: 05-21-12
05-22-12 12:40 PM - Post#2228659
I'm in Houston, TX. Not in a super big hurry to get moving on the project. The body is pretty straight as side from a few small patch areas. However I've got a '63 Nova with an LS1 that I'm 98% done with that I need to get on the road first.
About the '54 front end swap:
Ultimately, this came into play because someone near by has enough parts to do this rather than me waiting around for a '53 splash and bumper and pay for shipping. He's also got a lot of the glass & rear bumpers that I'm missing so I thought I might just go grab the whole lot. And I also am more partial to the '54 grills than the '53s.
That being said, if anyone's looking for '53 fenders that with the trim that are near perfect let me know
Also, is there a specialist parts website for these cars? I've found a few that carry a bit here and there for the car, but no site that would ultimately be a one stop shop for replacement parts.
ChrisBorsheim
Loc: Houston, TX
Reg: 05-21-12
05-22-12 12:45 PM - Post#2228660
Figured I'd post a pic or two
The the nova that needs to get finished already
dsacton
Loc: Boulder, CO
Reg: 11-01-11
05-22-12 12:57 PM - Post#2228664
My 54 Bel Air has a 53 oil presure gauge, which only goes up to 30 psi (instead of 60). No worries, I just make sure that the needle is pegged, and all is well oil pressure-wise.
Scott Acton
1954 Chevy Bel Air 2-door
http://www.my54chevy.com
whiskey1954
whiskey1954
Loc: central north carolina
Reg: 12-07-08
05-22-12 01:43 PM - Post#2228679
National chevy assoc. of St. Paul is a good source for 53-54 parts
Edited by whiskey1954 on 05-22-12 01:44 PM. Reason for edit: No reason given.
Happy Belair
Reg: 10-29-06
05-22-12 02:57 PM - Post#2228709
than you have a late production 53
Early production were cloth.
Happy Belair
Reg: 10-29-06
05-22-12 03:04 PM - Post#2228711
basically on the radios there were the push button and the manual is what I was referring to
On the door handles, most of the bodys the door handles mount just below the beltline moulding on the Hardtop and Convert they mount about two inchis lower on the door. That gets themout of the way of the wide window frames of the converts and Hdtps. also the retainer clips for the door handles are about 1 inch longer
ask me how I know THAT ONE
05-22-12 11:02 PM - Post#2228835
I always thought the push-button and manual radios were just the expensive and cheap models for both '53 and '54. But that was just my guess--never saw enough of them in the wild to make a judgment.
kool53
Loc: Mukwonago, WI
Reg: 06-18-04
05-24-12 07:15 PM - Post#2229462
If your buying guages, watch the speedo. While the are the same unit, the speedos from the 150 models will not have a chrome disk in the center like the 210's did. It will work fine, just won't look right.
Happy Belair
Reg: 10-29-06
05-24-12 08:16 PM - Post#2229480
    In response to kool53
good pint and also, the guage bezel on the 150 will not have a chrome inner bezel but will be all one color
Execution time: 0.093 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:59 PM
