Username Post: Actuator rod in steering column        (Topic#280952)
BigSteve13
BigSteve13
Reg: 05-10-12
05-10-12 07:45 PM - Post#2224647
Help please !! Have a 94 Suburban with tilt wheel. the ignition switch on the column went bad. Replaced it but the actuator rod is also broke. Ordered new one and I have no clue how it goes in. I also have a new rack and gear ?? that need to be put in. I was told this goes with the actuator rod. I need some diagrams or step by step directions. First time attempting something like this. Thank you !! need this done this weekend before the wife goes back to work.
05-11-12 05:12 AM - Post#2224743
    In response to BigSteve13
Dunno if this is detailed enough to help, but it's straight from the factory service manual. If your browser scrunches it up, expand it; the scan is 1128x1532 so it should be fairly clear.
http://www.someotherplace.com/info/col-ta01.jpg
BigSteve13
BigSteve13
Reg: 05-10-12
05-11-12 01:16 PM - Post#2224885
    In response to someotherguy
Thank you !! I'll give it a shot.
Execution time: 0.079 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:52 AM
