Username Post: clocking a wiper motor        (Topic#280895)
Black SD
Loc: TEXAS
Reg: 06-26-05
05-09-12 03:54 PM - Post#2224227
how does one 'clock' a 2speed wiper motor so that wipers operate without slaming into the lower windshield trim?
bowtieollie
bowtieollie
Reg: 12-06-99
05-09-12 06:07 PM - Post#2224287
    In response to Black SD
Hello Black,
The motor must be in the PARK position before attempting to "clock" it.
When you turn off the wiper switch, does the motor go to the PARK position?
If not - the old grease may be holding the switch open and create an issue trying to adjust the wiper arms.
Remove the old grease..... if that is the case.
Bowtieollie
Chevytalk.com Moderator
Black SD
Loc: TEXAS
Reg: 06-26-05
05-10-12 07:28 PM - Post#2224641
    In response to bowtieollie
it may be the switch Its a rebuilt motor.
without wiper arms the transmission arms operate nicely.
I put wiper arms and blades on and arms go up 1/2 way and stop?
bowtieollie
bowtieollie
Reg: 12-06-99
05-10-12 10:12 PM - Post#2224696
Hi Black,
Not abnormal.... with arms off, the motor can have "enough enertia" that it slips past the park switch.
The drag of the wipers on the glass - does help with the adjustment procedure.
Based on your assessment, it sounds like the switch is out of adjustment.
Bowtieollie
Black SD
Loc: TEXAS
Reg: 06-26-05
05-11-12 09:49 PM - Post#2225040
thanks
Ndee
Loc: Hamburg, Germany
Reg: 08-14-10
05-21-12 01:00 AM - Post#2228076
Do you have the inspection & service manual for the wiper at all? I have and it helped a lot, because it contains exactly these informations (also wiring, test-procedures, etc.)
1958 Chevy Brookwood, V8 350, 6P
Black SD
Loc: TEXAS
Reg: 06-26-05
05-22-12 08:05 PM - Post#2228807
    In response to Ndee
no i do not have the mentioned data.
any chance you can post or send this?
Ndee
Reg: 08-14-10
05-22-12 11:59 PM - Post#2228842
Check your private topics... :-)
Black SD
Loc: TEXAS
Reg: 06-26-05
05-23-12 02:47 PM - Post#2229055
    In response to Ndee
outstanding information!!!
UncleStubbs
Reg: 01-02-13
01-02-13 05:54 PM - Post#2303458
Any chance I can get that information? When I bought my '59 the PO said he replaced the wiper motor at some point and they worked like they should. Then he said at some point they started cycling backwards and parking in the wrong position (horizontally) He had just ignored it and used them that way but they also scratched up the glass where it bends. I would like to correct the problem but not sure where to start. It also seems like the wiper switch is inconsistent as I can turn it on and manually park them at the cowl by turning them off, but then eventually they will automatically park horizontally without me touching the switch. This is the last of the quirky electrical things I need to fix on this car. Please help!
UncleStubbs
Reg: 01-02-13
01-02-13 06:35 PM - Post#2303473
    In response to UncleStubbs
I meant to say "vertically" not horizontally. How do I edit a post?
Jerry Acheson
Jerry Acheson
Loc: Glenview, IL
Reg: 12-30-00
01-02-13 06:55 PM - Post#2303482
For a short time after you post, you will see 'edit' in the blue bar at the bottom right corner of your post. Click that and you will get a window with your text. You can edit there. The bottom of the edit screen will give some options.
Links to:
57 Chevy 3100 Pickup
59 Impala Sport Coupe
bowtieollie
bowtieollie
Reg: 12-06-99
01-02-13 07:30 PM - Post#2303498
Sounds to me like the grease is hard inside the wiper motor and the park switch is not functioning properly.
Best bet is to remove the wiper motor, open up the cover (not the motor) and clean out the old grease.
Then readjust the parking switch.
Bowtieollie
mrbuck
Loc: nor cal
Reg: 01-05-13
01-05-13 04:50 PM - Post#2304308
i too have a similar issue, they seem to "park in the correct position but will stop at the vertical postion and begin to click, once turned off they return to the prper park postion. could this be built up grease too?
Execution time: 0.094 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:18 PM
