Username Post: Power steering help        (Topic#280810)
kzhurley
Loc: Millersburg,Ohio
Reg: 01-02-12
05-07-12 07:26 PM - Post#2223599
Hello I have a 50 2 door sedan that converted over to the cavalier rack and pinion and i need some assistance on the pump.. I have a 58 348 with the generator/power steering and im not sure if i need to lower the pressure coming out of that pump for the r&p i have.. Ive heard that the cavalier racks need around 1000 psi but i cant find ANY info on the ps/generator setup..
Ive used gm metric pumps in the past for this purpose and just welded up the hole in the regulator part but im not sure if the procedure is the same on this one..
Any help is appreciated..
THANKS
05-07-12 07:35 PM - Post#2223601
    In response to kzhurley
Are you saying your '50 2-door is running a '58 348 engine? If so, you MUST post some pictures!!
As far as your P.S. question, I doubt the '58 P.S. pump puts out a lot more than 1,000 PSI, but I'm not sure. The stock '53-'54 P.S. pump is supposed to put out between 750 and 900 PSI, according to the Shop Manual. Did GM amp up the P.S. pump by '58? I don't know. CT member Jalapeno would know--he's an expert on old Chevy P.S. systems, but I'm just an inspired amateur on these old P.S. systems.
kzhurley
Reg: 01-02-12
05-07-12 07:41 PM - Post#2223605
Yes running a 58 280 hp 348 But not moving or stopping it yet.. Long way to go.. Tommorrow i need to start a post and put up some picks...
Jim McCall McShop
Jim McCall McShop
Loc: Billings Mt/ Lake Havasu ...
Reg: 02-18-10
05-07-12 08:03 PM - Post#2223609
We'll be waiting, as we love photos.
33 Ford 3-window
34 Ford Roadster
51 Belair
55 Belair
55 Belair
57 Buick
68 Camaro SS427
69 Camaro Z/11
71 Camaro Z/28
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
05-08-12 04:07 AM - Post#2223675
    In response to Jim McCall McShop
please photo's!! big fan of 348/409 stuffed it 49/54 cars my first was a 49 coupe with a 409 .but no power steering
53Chevy
53Chevy
Loc: Davenport, IA
Reg: 02-18-04
05-08-12 02:58 PM - Post#2223870
    In response to arnieg141
Before I put the Jag front end under it I use the Vega rack. I used the GM Second Generation pump and remote reservir with it. It worked well for me except I had the front end lowered 3" and the rack set to low to the ground. Just my comment.
Jalapeno
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
05-10-12 09:35 PM - Post#2224682
The gen mounted pump is rated at 750 psi, it will do well in the 600-800 range for it's original application.
I have no idea what the Cavalier rack requires.
You can get an adjustable valve to tone down the pressure if needed, it connects in line with the pressure hose, look at Heidt's or Summit or Jegs.
And yes, please post pix!
Jalapeno
kzhurley
Reg: 01-02-12
06-09-12 08:44 AM - Post#2235098
    In response to Jalapeno
http://s1236.photobucket.com/albums/ff452/kzhurley ...
Heres some pics
Edited by kzhurley on 06-09-12 08:45 AM. Reason for edit: No reason given.
fbama73
fbama73
Loc: Indianapolis
Reg: 04-17-10
06-09-12 09:32 AM - Post#2235107
As much as I like these cars with 6 bangers, the 348 is a SWEET choice!
My '51 Styleline Spl. build: http://51kustom.blogspot.com/
Jalapeno
Jalapeno
Reg: 04-30-00
06-15-12 09:48 PM - Post#2237676
Thanks for the pix!
I noticed the 348 has an alternator now, will you change it over to the gen/pump if the pressure proves to be OK?
Jalapeno
kzhurley
Reg: 01-02-12
08-16-12 03:00 PM - Post#2260010
Sorry ive been gone for a while... The pump/generator worked out fine.. I just need to put new seals in it.. Its almost road worthy now
Jalapeno
Jalapeno
Reg: 04-30-00
08-16-12 07:05 PM - Post#2260091
No worries.
Did the pump work OK as is, or did you need to reduce the pressure?
Jalapeno
kzhurley
Reg: 01-02-12
08-19-12 11:16 AM - Post#2260952
The pump pressure seems to be ok. You can turn it pretty easily when your stopped and it still has steering feel when your driving
Execution time: 0.088 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:51 AM
