Donnie56
Loc: Beaumont,Calif.
Reg: 05-17-04
05-06-12 08:30 PM - Post#2223279
Hey guys, Friend of mine just had his '51 completely rebuilt 216, 3 sp.trans, and his trans is giving him trouble. It won't down shift into 2nd gear with out grinding. The guy that rebuilt it said mybe the cheap Chinese syncro is bad. Are there better parts out there to buy than the Chinese stuff?any advice would be very helpful.
This
Forum is Sponsored by
RICKYRICARDO
Loc: Milwaukee WI
Reg: 10-31-11
05-06-12 08:50 PM - Post#2223282
In response to Donnie56
Maybe the rebuild was bad? take it out inspect it how old is the rebuild?
Winter is a grand old time,
there are no ifs or buts/But remember all that salt and grime/Can rust your bolts and freeze your -... |
Ross_S
Loc: Pahrump, NV
Reg: 07-05-02
05-06-12 09:29 PM - Post#2223286
In response to RICKYRICARDO
Clutch adjustment?
05-06-12 10:20 PM - Post#2223299
In response to Ross_S
I didn't know the Chinese were even making synchros for the '49-'54 3 speed transmissions. Those are difficult synchros to replace. But you would think even cheap synchros would last for awhile anyway. My bet is clutch adjustment or linkage adjustment.
fbama73
Loc: Indianapolis
Reg: 04-17-10
05-06-12 11:16 PM - Post#2223306
The guy that rebuilt it is blaming cheap parts? Exactly who was it that put those cheap parts in the trans in the first place? I smell a cop out.
Edited by fbama73 on 05-06-12 11:16 PM. Reason for edit: No reason given.
prowler
Loc: Port Alberni B.C.
Reg: 01-15-12
05-06-12 11:34 PM - Post#2223308
In response to fbama73
I recently blew up the 3 speed on my 52. I was given a few by variouse friends that had different mounts on them so a local guy took the best parts out of one, and put mine back together again. The car is much smoother now, but it also has the grinding problem going in to second either up or down. he said to pull it out and he will see what he can do but I dont hink I will bother as I am acumulating parts for a 5 speed swap asap.. he figured maybe there is a bit of crap in the syncro not allowing it to do its thing? It was the better of the 2 that he had to work with, so he is a bit stumped as well. When I saw the one that came out of it originaly, I am amazed it was working at all, and so was he..
This
