Username Post: Bank 1 reading lean        (Topic#280655)
Tritip
Tritip
Loc: Cali
Reg: 05-21-09
05-04-12 05:47 PM - Post#2222508
What would fix this? It happens every now and again. Twice both 1 and 2 read lean. Is there anything I can do to fix this. Other then clearing the codes when they pop.
1996 350 5.7L 80MM throttle body, aftermarket mass Air flow, K&N full intake, MSD Coil, and short Headers.
I replaced the O2's about 30,000 miles ago maybe less.
96 Chevy 1500 5.7l
05-04-12 06:05 PM - Post#2222515
    In response to Tritip
Checked fuel pressure lately? Still running the original poppet valve setup and how many miles are on that?
ltlvt
Loc: Wichita Falls Texas USA
Reg: 09-17-00
05-04-12 06:27 PM - Post#2222524
    In response to someotherguy
As small exhaust leak will bleed O2 into the system causing the ECM to think it is lean.
Runs like a Scalded Dog!!
Tritip
Tritip
Loc: Cali
Reg: 05-21-09
05-05-12 08:15 AM - Post#2222678
I have not checked the pressure as of late (if I remember correct, should be 52psi?). The original Poppets are still on there, rolling with 111340 mile as of yesterdays drive home.
**I don't think there is an exhaust leak (I will double check)**
96 Chevy 1500 5.7l
05-05-12 03:39 PM - Post#2222852
Fuel pressure info in the FAQ but short and sweet, factory spec is 58~62 psi on the Vortec small block.
Execution time: 0.099 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:20 AM
