ejw71
Loc: Fayetteville, AR
Reg: 01-19-01
05-02-12 04:45 PM - Post#2221673
Want to change my '86 from R12 to R134a. There are so many kits out there one doesn't know where to begin. Please advise as to what procedure to follow. Thanks, Ed
54 Corvette 235 PG 3.55
59 El Camino 348 700R4 3.36
63 Corvette 327 PG 3.36
68 Impala SS 327 700R4 3.73
71 Monte 350 350 2.73
71 Monte under the wrench
79 El Camino 350 350 work horse
86 Corvette 350 700R4 2.93
11 Corvette GS 376 6sp fast
bowtieollie
Reg: 12-06-99
05-02-12 07:58 PM - Post#2221784
In response to ejw71
Hello EJ,
Use the kit which includes adapters for the "hi-lo" fittings. That is all you will need.
Charge to 80% of the original specification R12 charge and you should be "good to go"
Nothing else needs modifications.
Bowtieollie
Chevytalk.com Moderator |
ejw71
Reg: 01-19-01
05-03-12 07:17 AM - Post#2221908
In response to bowtieollie
Thanks BowTie, I'll do it.
Capr87Elco70
Loc: New York
Reg: 06-24-02
05-06-12 09:06 PM - Post#2223284
You can still get R-12 on ebay if you apply for the certification. Personally I'd just change the o-rings and put r-12 back in. I always read that it cools better.
-Shawn-
1965 Olds F-85 Deluxe
1983 Olds 98 Regency Brougham
1987 Caprice Landau Sport Coupe
1970 El Camino RIP 1-1-05
ejw71
Reg: 01-19-01
05-09-12 05:20 PM - Post#2224270
In response to Capr87Elco70
Rather than change will try the Freeze 12 substitute.
bowtieollie
Reg: 12-06-99
05-09-12 06:23 PM - Post#2224300
Be careful with the FREEZE substitute.
It contains PROPANE - therefore, you A/C system becomes EXPLOSIVE.
The 134 will work fine - that is if you do not have access to R-12. Be careful what you buy on Ebay - as they call it R-12 and it is a substitute. I would only consider NAME BRANDS or factory sealed containers.
Bowtieollie
wagonmaster
Loc: Loganville, Ga.
Reg: 04-28-00
05-13-12 04:03 AM - Post#2225341
Some folks claim that you will need to replace the expansion tube with one from an R134 system, too...I'm not 100% sure, but folks that are in the know have told me this more than once......Can't hurt to do it.
bucky katt
Loc: Columbia South Carolina
Reg: 04-27-12
05-15-12 12:57 AM - Post#2226028
In response to wagonmaster
i know that when i did the conversion on my Silver Anniversary coupe (1978) the compressor, evaporator orifice and drier. i looked on Ecklers and the kit to convert your car has the same parts along with new o-rings, and a bottle of the proper oil for the system. it works great too.
rat in a drain ditch, dogs in a pile
nothing left to do but SMILE SMILE SMILE! |
Edited by bucky katt on 05-15-12 01:04 AM. Reason for edit: No reason given.
