Username Post: cracked transmission caseck questio        (Topic#280385)
mbrb
Reg: 04-29-12
04-29-12 05:22 PM - Post#2220371
newbie here and I have a quick question--just replaced my transmission on a 1995 GMC Yukon(due to a big crack in the top of the case near the tail where the transfer case bolts on) drove the vehicle 20 miles and now the new transmission has a bigger crack on the bottom of the transmission case where the transfer case bolts to the transmission.Someone said that the frame is bent causing the transmission to crack and I was wondering how to tell if the frame is bent and if it is how to straighten it.The Yukon has a six inch lift kit(procomp) on it with a 5.7 engine. Any help on this would be appreciated seeing as how I just wasted $800.00 on a transmission.
drifterdude
Reg: 09-04-08
04-29-12 06:45 PM - Post#2220416
    In response to mbrb
do you have the driveshaft slip joints greased? If not when the axles move up and down with flex it will exert force on the transfer case cracking the tranny.
I have done this before.
92 K1500:350 bored 30 over,built 700r4,Comp extreme energy cam,double roller timing set,shaved heads,Rancho RS9000XL series shocks with wireless my ride system,35 inch Mickey Thompson Baja Claws,Relocated 4x4 switch to rocker on Dash.
Other mods..
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
04-29-12 06:55 PM - Post#2220420
    In response to drifterdude
interesting. I havent seen a broken or damaged frame crack one yet, could be just me but I have driven some trucks with nasty broken frames and they just sem to ride smoothly, lol.
Anyway I second checking the slipjoint because of the extra force it would exhert on the trans housing. But you say it is cracking where the transfer case bolts on. Can you post a pic?
GM fan FOREVER
Edited by rockfangd on 04-29-12 06:59 PM. Reason for edit: No reason given.
mbrb
Reg: 04-29-12
04-29-12 08:44 PM - Post#2220467
thanks for the suggestion of the drive shaft slip joint.I did forget to mention the there was a very noticeable amount of vibrations when under power and when braking.It didn't occur to me that it might be something associated with the drive shaft.Thanks again I am going to check it out tomorrow and see how easy the shaft slides in and out of the transmission.
drifterdude
Reg: 09-04-08
04-29-12 10:39 PM - Post#2220495
    In response to mbrb
if its 4x4 check both front and rear. Front should have a splined slip section as well.
The DAs that built my tranny when they had it apart did not check the driveshafts and a week later I broke my housing. Granted their warranty paid for it as it was supposed to be done by them along with Ujoints... But anyways Mine broke where the transfer case meets the tranny on the upper side just above the cross member.
Other mods..
Execution time: 0.13 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:00 PM
