Username Post: harmonic damper replacement?        (Topic#280092)
tony hill
Reg: 04-08-12
04-23-12 01:59 AM - Post#2218127
Hi,how do I go about putting my harmonic damper back on my crank?As my 327 crank has no thread in the nose,I had to use a good puller to get the thing off -and it took some doing!Don`t want to damage anything so some advice would be great.I have fitted a repair sleeve to the damper where it goes in the front cover,it was leaking here.
Thanks from Tony.
models916
Loc: Addison, IL
Reg: 05-28-10
04-23-12 07:17 AM - Post#2218190
    In response to tony hill
Chevrolet shop manual says to use a big hammer. Could drill and tap the crank and pull it on.
awsum55
awsum55
Loc: O.P. Kansas
Reg: 09-27-01
04-23-12 11:34 AM - Post#2218262
Some people put the dampener in the oven at around 200º and pack the crank with ice. It should make it easier to beat the thing on. Don't go any hotter than 200º because there is rubber inside that could get damaged with too much heat.
I don't think the ice is really necessary though. Don't forget to wear thick gloves when you remove the balancer from the oven.
Five things that you cannot recover in life:
* The Stone after it's thrown
* The Word after it's said
* An Occasion after it's missed
* The Time after it's gone
* A person after they die
jdk
Loc: columbus, ohio
Reg: 02-15-10
04-23-12 05:16 PM - Post#2218409
    In response to awsum55
after heating use a 2x4 across it. then i would look
into having the crank tapped for a bolt. jmho jim
tony hill
Reg: 04-08-12
04-27-12 11:47 AM - Post#2219697
    In response to models916
Hi,thanks for the reply,I think I will warm it up & try it that way.Cheers.
Doc Fillem
Reg: 04-17-12
08-23-12 08:25 AM - Post#2262393
I put a thick piece of steel on the balancer and hit that with the hammer. You get too much bounce with a 2x4.
Execution time: 0.098 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:37 AM
