tbrown8338
Reg: 03-25-12
04-19-12 07:25 AM - Post#2216843
have anyone out there had any dealing with replacing the channel guide on a 49 chevy pickup. it is the part that the window channel runs in on the front lower inside of the door. mines have rusted off and the glass falls out when i let it down. thanks for your help.
TooMany2count
Old as Dirt Member
Loc: Cahokia, IL
Reg: 12-12-01
04-19-12 09:44 AM - Post#2216891
In response to tbrown8338
Here's some pictures that MotherTrucker(HAMB member) has showing the inside of the door. Not going to be easy or fun. You may have to open the the inside of door up OR if your handy enough you may get away w/either drilling a hole through the door into the end of the channel where it is suppose to be spot welded and either use a screw or weld it back up....joe
Link to post on HAMB....joe
Donate Blood Products
Two possibilities exist:
Either we are alone in the Universe or we are not.
Both are equally terrifying.
Arthur C. Clarke |
55 Shaker
Loc: north central IL.
Reg: 03-13-06
04-19-12 10:39 AM - Post#2216915
In response to TooMany2count
Joe would you know where there are some pictures like that for a 55.2-56 Chevy 3100 truck?
TIA. Brian
| The older I get, the more dangerous, I am !!!! |
TooMany2count
Old as Dirt Member
Loc: Cahokia, IL
Reg: 12-12-01
04-19-12 10:30 PM - Post#2217144
In response to 55 Shaker
None yet, but you may ask over on Stovebolt.com if anyone may have pics or see if someone has a junk one & would cut it open like MT pics above....joe
Arthur C. Clarke |
Nomad Jack
.jpg)
Loc: Cape Cod, Ma.
Reg: 03-14-03
04-20-12 05:00 AM - Post#2217179
I don't have any images like those, but the 55-56 inner door looks very much the same.
55 Shaker
Reg: 03-13-06
04-20-12 10:52 AM - Post#2217271
In response to Nomad Jack
Thankyou for your replies.
