Username Post: 53 gmc master cylinder        (Topic#279883)
bad67nova
Reg: 04-18-12
04-18-12 04:50 PM - Post#2216639
i have a 53 gmc pick up truck i just did the brakes on it but the pedal isnt returning is there a return spring on the pedal if so how does it route
bobschevytrucks.com
TooMany2count
Old as Dirt Member
TooMany2count
Loc: Cahokia, IL
Reg: 12-12-01
04-19-12 09:15 AM - Post#2216881
    In response to bad67nova
on the Chevy's the brake pedal Return Sping connects to a hole on the pedal and then uses about a foot long double hooked piece of spring wire to pull it tight & hook it into a hole in the transmission x-member(I believe) or a tab w/hole in it either on the x-member or frame. It's been a while since I have been under a stock truck to remember exactly where the other end hooks too....joe
Donate Blood Products
Two possibilities exist:
Either we are alone in the Universe or we are not.
Both are equally terrifying.
Arthur C. Clarke
bobschevytrucks.com
Execution time: 0.089 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:43 AM
