Username Post: drive train swap        (Topic#279728)
low54
low54
Loc: Joliet, IL
Reg: 02-23-11
04-15-12 08:16 PM - Post#2215559
Getting ready to start a drive train swap. Now before I go the small block route, I was wondering if anyone converted from automatic to a late model stick. I would like to keep the 235 but have not come across any solutions to the kick down cable for a dual carb set up. So I wanted to see if anyone did a old powerglide to late model manual swap before I buy a small block and go that route. I know I have to find and get the pedals and linkage, but I'm thinking about the bell housing differenaces.
1954 210 Del Ray daily driver
RhinoRay
RhinoRay
Loc: Kelseyville
Reg: 02-27-07
04-15-12 10:17 PM - Post#2215599
    In response to low54
Have you tried to find a bell housing from a
235 or 216? You can bolt a T-5 transmission from a S-10 with a few modifications. Click on my transmission link below to check it out. It bolts up to the original clutch etc. The brake master cylinder holds the brake and clutch petals.
I'm not sure what to do about the kick down cable for a dual carb set up, mine are progressive.
RhinoRay
52 Chevy Coupe
Kelseyville, CA
Slide Show Of The Project
Intake, Exhaust, Tranny
low54
low54
Loc: Joliet, IL
Reg: 02-23-11
04-16-12 07:14 AM - Post#2215669
    In response to RhinoRay
Thanks for the links. I do not have a the bell housing yet. Since it's a 54 235, only a pre 55 bell housing will work right?? Also I noticed in the pics that you are running a different master cylinder. Are you using the stock pedal or something different?
VANDENPLAS
VANDENPLAS
Loc: ontario canada
Reg: 07-29-09
04-16-12 08:45 AM - Post#2215711
55 AND LATER BELL HOUSING IS WHAT YOU NEED.
you use the stock pressure plate with an 11" s10 or stick astro van clutch plate.
you will need to trim the input shaft of the trans about 1/4 inch
and cut the old cross memebr out and fab up a new one.
do a search on here or the hamb for "ultimate t5 thread" there is more then enough info in there to get you hot and happy about rowing gears.
Every mother on Earth gave birth to a child.Except my mother,she gave birth to a legend .
ALWAYS TRUST PEOPLE WHO LIKE BIG BUTTS,THEY CANNOT LIE.
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
04-16-12 08:53 AM - Post#2215716
    In response to VANDENPLAS
VAN THE 1949 TO 54 6 CYL. CHEVY GMC PICK UP BELL WORKS PEREFECT YOU CAN EVEN USE THE THROW OUT BEARING ARM. AND BOLTS TO ALL 55 UP TRANS.
Edited by arnieg141 on 04-16-12 08:54 AM. Reason for edit: No reason given.
low54
low54
Loc: Joliet, IL
Reg: 02-23-11
04-16-12 09:29 AM - Post#2215732
    In response to arnieg141
So a 55 and later bell housing will work? But isn't it a different bolt pattern. Or a pre 54 truck bell housing. I will see what I can pull up on the HAMB.
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
04-16-12 10:06 AM - Post#2215743
both 55/56/57 cars & pick up and 49 to 54 gmc/chevy pick up use same trans.bolt patern for 55 up trans.all use same starter counting.
VANDENPLAS
VANDENPLAS
Loc: ontario canada
Reg: 07-29-09
04-16-12 11:44 AM - Post#2215772
55 and later car bell housings work great
49 and later truck bell housings work, but from what i have heard and read the release arm is in the wrong spot and requires some gaffering to make work with the stock pedal set up.
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
04-16-12 12:05 PM - Post#2215776
I MENT STARTER MOUNTING
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
04-16-12 12:10 PM - Post#2215777
TRUE VAN IF YOU DON'T HAVE THE ORGINAL .THE 55/56/57 CAR/TRUCK AND THE 49 TO 54 NEED A LITTLE PLAING WITH. BUT IF YOU DO HAVE THE ORG.RELEASE ARM .IT'S A PERFECT FIT WITH THE 49 TO 54 TRUCK BELL
Edited by arnieg141 on 04-16-12 12:11 PM. Reason for edit: No reason given.
low54
low54
Loc: Joliet, IL
Reg: 02-23-11
04-16-12 12:19 PM - Post#2215781
What about a 51 car bellhousing. I saw one on ebay for sale. Correct me if I'm wrong but didn't 55 and up have the modern day bolt pattern. I thought that's why they make the adaptors for the 54 motors to run a newer trans.
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
04-16-12 12:23 PM - Post#2215783
49 to 54 car bell no good for 55 up trans. unless your doing t-5 trans. then you can use but need adaptor plate
low54
low54
Loc: Joliet, IL
Reg: 02-23-11
04-16-12 12:26 PM - Post#2215786
So that bell would work, just as long as you go with the adaptor from buffalo enterprises
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
04-16-12 12:34 PM - Post#2215789
low as far as i know only for the t-5 trans.. not for 55 up 4 speed or 3 speed
low54
low54
Loc: Joliet, IL
Reg: 02-23-11
04-19-12 06:09 AM - Post#2216820
Well got a 54 motor and trans with the bell housing that I needed for a whopping $11.00 I know the 80's s10 trans was mentioned. But looking around some people said a camaro trans would work. Anybody use one? Now correct me if I'm wrong but a t-5 trans has the 4 bolts that bolted to the bell housing?
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
04-19-12 06:56 AM - Post#2216834
80 s-10 rear is fine..no on trans..camaro is good trans..you need an adaptor to your bell houseing go rhinorays post here for your needs .i he shows his adaptor.. if you get a rear get all the emerg.brake cablels from rear forward about to where your trans is
Edited by arnieg141 on 04-19-12 07:00 AM. Reason for edit: No reason given.
low54
low54
Loc: Joliet, IL
Reg: 02-23-11
04-19-12 09:00 AM - Post#2216874
I have a 55 rear that I got from Bill. Just wondering what other vehicles I can look for besides the s 10 for the trans.
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
04-19-12 09:21 AM - Post#2216883
SHOULD BE ANY OF THE GM t-5 trans as long as its from a -- NONE-- 4 wheel drive...camaro/firebird .s-10 pick up gmc sonoma ...JUST MAKE SURE IT'S THE MECHANICAL SPEEDOMETER
usmile4
Loc: Naperville, Illinois
Reg: 08-12-05
04-19-12 10:22 AM - Post#2216907
The S10 T5 puts the shifter forward where you need it. The other T5's will have the shifter too far back. The adapter allow you to bolt the trans to the earlier bells. You do have to drill out the mounting holes as the T5 is metric and you need a 1/2" to mount to the adapter. The T5 is aluminum so it is an easy drill with a 1/2" bit.
T5 information. This will give you the answers to most of your questions. Read Ray's post above also.
Bill Gommel
RhinoRay
RhinoRay
Loc: Kelseyville
Reg: 02-27-07
04-19-12 03:16 PM - Post#2217003
    In response to usmile4
I looked at the camaro transmissions and they were not right, check out the link above and your can't go wrong. If you are planning to put an electronic speedometer in you can use the later models but I elected to get mine rebuilt so I had to get an earlier model. There is a way to adjust the speedometer so as to make it accurate.
I got a rear end from a S 10 4X4 which is a bit narrower than stock would be. That allowed me to put in wider wheels in the back and allow for clearance.
RhinoRay
52 Chevy Coupe
Kelseyville, CA
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
04-19-12 05:04 PM - Post#2217032
i remember that ray the camaro/firebird shifter to far back. i should have remembered that i was given on free and could not use so i went 4 speed. and gave back the trans.i cleaded out my shed when i get ready for next car i found the m22 rock crusher and hurst from a 68 396 chevell
low54
low54
Loc: Joliet, IL
Reg: 02-23-11
04-20-12 08:14 AM - Post#2217226
Thanks I will continue to look for the S10 trans. I just hoping to broaden my search a little more. I picked up my $11 motor and trans yesterday. So now I have more pieces for the swap. As a bonus it looks like it's a full pressure instead of a dipper in front of the 3 speed.
low54
low54
Loc: Joliet, IL
Reg: 02-23-11
04-25-12 01:46 PM - Post#2219035
The old powerglide is out. I got my bellhousing from a 54. Waiting for master cylinder and clutch pedal to arrive. Going to get some more pieces tonight. Hopefully should be getting an 87 s10 t5 Monday. Now correct me if I'm wrong but it looks like I need the clutch disk from the s10 and the pressure plate from the 54? Also any difference in the throw out bearings?
Edited by low54 on 04-25-12 01:48 PM. Reason for edit: No reason given.
low54
low54
Loc: Joliet, IL
Reg: 02-23-11
05-07-12 08:35 AM - Post#2223412
Got the posie springs friday before I left for Vintage Torque Fest. Going to put the rear in today. The salvage yard that had my trans I needed no longer has it. I know the elect speedos trans will work. How much of a pain is it to convert to mechanical. I'am finding a lot more of these.
Execution time: 0.081 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:38 AM
