tarps (7)
Username Post: Timing Gears        (Topic#279673)
Elliott Services 907
Loc: Ak.907
Reg: 01-13-10
04-14-12 07:16 PM - Post#2215167
Trying to change to Gear to Gear timing in my 1990 5.7l. Lost the instructions,now not sure about alignment of the 3 timing marks.Any ideas?
patgizz
Senior Moderator Member
patgizz
Loc: Cleveland, OH
Reg: 01-30-00
05-11-12 06:29 PM - Post#2224979
    In response to Elliott Services 907
which 3 marks? does your crank pulley have 3 notches? if so it can go on -4, 0, and +4.
65327
Loc: ohio
Reg: 05-13-12
05-25-12 04:01 AM - Post#2229556
there should be a triangle, square, circle. the triangle is 4* advance, the square is 4* retard, the circle is the stamdard timing position for most applications. I still had my instruction sheet and that is straight from it. looked at it as I typed this.
Execution time: 0.081 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:46 AM
