Username Post: Engine Paint/Paint Related Questions        (Topic#279668)
RumblingV8
RumblingV8
Loc: Allentown, PA
Reg: 03-11-12
04-14-12 05:14 PM - Post#2215138
Here's a legitimate question for you guys.
The orange paint on my engine block and all related orange parts is in very poor condition. I probably will not be painting the block any time soon, but i do have the valve covers cleaned up, and those are ready for paint. What brand/color orange did you use to repaint any of the orange components under the hood?
Also in regards to painting, would you recommend that I invest in a paintgun setup? For most of the smaller parts i have used simple high heat primer/paint in a spray can, and it is turning out well (I am taking my time not to mess anything up) so far. I am open to suggestions.
Jerry Acheson
Jerry Acheson
Loc: Glenview, IL
Reg: 12-30-00
04-14-12 06:51 PM - Post#2215160
    In response to RumblingV8
I've had very good luck with DupliColor Chevy Orange in a rattle can.
Links to:
57 Chevy 3100 Pickup
59 Impala Sport Coupe
62sedan
62sedan
Loc: North Dallas area
Reg: 08-12-02
04-15-12 05:43 AM - Post#2215259
    In response to Jerry Acheson
x2 on Jerry's choice of DupliColor, and it's available at most parts stores.
Chuck
RumblingV8
RumblingV8
Loc: Allentown, PA
Reg: 03-11-12
04-15-12 07:53 AM - Post#2215299
    In response to 62sedan
Thanks! I'll check it out, guys.
Home Depot is probably the closest place with spray paint, and that's where i usually go for supplies, but they only have Rustoleum brand. I was looking up orange paints, and some places had it labeled as "Chrysler Hemi Orange", and I certainly don't want that!
Jerry Acheson
Jerry Acheson
Loc: Glenview, IL
Reg: 12-30-00
04-15-12 09:46 AM - Post#2215340
You can probably get it at Walmart if you don't have a car parts store around. You are looking for Chevy Orange engine paint.
Links to:
Edited by Jerry Acheson on 04-15-12 09:49 AM. Reason for edit: No reason given.
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
04-15-12 11:52 AM - Post#2215379
get several cans. sometimes different cans from a different lot and certainly different brands are a different shade of chevy orange.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
11 malibu (new)
Jerry Acheson
Jerry Acheson
Loc: Glenview, IL
Reg: 12-30-00
04-15-12 12:32 PM - Post#2215390
    In response to 62chevy427
Don't mix brands. Also, pay attention to the instructions. If not done correctly, the paint will lift. Pay attention to drying intervals.
Links to:
Willys36
Willys36
Loc: Bakersfield CA
Reg: 07-08-09
04-15-12 03:03 PM - Post#2215437
I've said in many places that I don't like any rattle can engine paint. I prefer catalyzed base cvoat/clear coat urethane, same as used on car bodies. IF you want to use rattle can stuff, be sure to paint the first with white primer. In fact white primer it first w/ catalyzed urethane too. Trying to cover the cast iron w/ color leaves it dull and dark and takes a lot of paint. The white undercoat makes the color pop w/ a pretty light coat.
“We can't solve problems by using the same kind of thinking we used when we created them.”
Albert Einstein
doubleE
doubleE
Loc: Eagan MN
Reg: 06-02-03
04-16-12 04:20 PM - Post#2215850
    In response to Willys36
Boy, I don't know... I think the DupliColor rattle can stuff POPs for me... I was going to post a pic of my engine but lost the link - sorry.
Eric
Willys36
Willys36
Loc: Bakersfield CA
Reg: 07-08-09
04-16-12 08:29 PM - Post#2215969
    In response to doubleE
It's OK; until you try the high end stuff! Base/clear urethane builds an almost powdercoat look and is a lot tougher than the rattle can stuff which seems to scratch just loooking at it. Regardless of what you chose, spray the engine w/ white primer. That base will make any color coat really glow.
Albert Einstein
Cdn63guy
Loc: Coquitlam, B.C.
Reg: 03-25-11
04-16-12 09:27 PM - Post#2215983
For what it is worth a while back here in Canada I purchased several rattle cans of engine enamel distributed and labeled under General Motors of Canada part #992652, orange. It was a product of the USA.
The closest product that I have found to compare with it is Dupli Color engine enamel ORANGE-RED DE1607. It used to be carried at Wal-Marts among others.
To me this orange-red is more to the original than Chevy orange.
The label says it is imported from the USA by Sherwin-Williams of Canada so I do not know if it is available in your country or not.
Gil
Jalapeno
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
04-16-12 09:40 PM - Post#2215989
I've used Plasticote engine paint, the V8 orange is a nice color. It lays on smooth and seems to get glossier as the engine is heated and cooled a few times.
Jalapeno
Jens
Jens
Loc: Emerson IA.
Reg: 04-21-02
04-17-12 07:03 PM - Post#2216345
    In response to Jalapeno
X2 Jalapeno. I've used both & the Duplicolor has more of a redder/orange tint. Here's the PlastiKote version.
64ss409
Reg: 12-04-02
04-17-12 09:18 PM - Post#2216388
    In response to Jens
I have used Chevy engine orange from PlastiKote and Krylon and like both, easy to use, good gloss. If I use a spray gun, I have them mix Hugger Orange from 69 Camaro or Chevelle or from 71 Chevy pickup.
Ron
1964 SS 409/340 4 spd, bought new Oct '63
1964 Biscayne-will have 409
1962 SS convertible 4 spd 327
1971 K10 454
99 Silverado Z11
1998 C5 convertible, torch red black top
prgm_mgr
Reg: 07-06-05
04-18-12 04:11 AM - Post#2216413
    In response to 64ss409
You asked about a paint set up.
I painted my engine and frame using the harborfreight gun that runs for around 10.00 on sale. I bought the plastic bags that go inside the canister at a auto paint shop as it allowed me to paint upside down under the car. They're like a heavyduty ziplock bag.
I used POR chevy engine orange I bought locally at an auto store. Seems to hold up well.
Mark
Edited by prgm_mgr on 04-18-12 04:12 AM. Reason for edit: No reason given.
RumblingV8
RumblingV8
Loc: Allentown, PA
Reg: 03-11-12
04-18-12 04:32 PM - Post#2216626
    In response to Jens
That color looks really nice! Thanks Jens! But why so many valve covers?
Thanks for the advice prgm, that is probably the route i will go in terms of a setup, then, unless anyone has any other suggestions.
mac1
mac1
Loc: Long Beach, Ca.
Reg: 08-26-02
04-18-12 05:48 PM - Post#2216674
Ditto on the duplicolor chevy orange 500 degree ceramic paint. This paint holds up well and touches up very well. This would be part # DE 1620.
Mac
1962 Impala SS Convertible
Dual Quad 409, 4 Speed Posi Traction
https://sites.google.com/site/macs409superspor t/
Timothys Chevy
Timothys Chevy
Loc: Fredericton, New Brunswic...
Reg: 09-24-03
04-25-12 04:40 PM - Post#2219089
    In response to mac1
Just make sure there isn't any trace of grease left on the motor, or rust.
~~Timothy~~
1984 Chevy Citation 2.5
2009 Pontiac Vibe AWD
1993 Buick Park Avenue
2001 Pontiac Sunfire GTX
Execution time: 0.118 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:25 AM
