of this great
online community.
zackmorris
Reg: 04-05-12
04-05-12 10:53 AM - Post#2211676
ok, the bracket that holds the tension pulley, etc. became wobbly my belt loosened and can no longer drive, so i explored, found that the bracket snapped at the bottom screw an a screw at the top had sheared off the head, now the screws in the head and ive tryed the screw removal tools. im to the point of tap and die. can i remove the fan without concern? i def. dont hve the money for mechanics so its a diy project
S10Fanatic
Loc: Eastern NC
Reg: 09-18-11
04-06-12 10:13 AM - Post#2212050
In response to zackmorris
Yes you can remove the fan.
Have you drilled the bolt and tried a easy out. If not start with a small bit and drill a pilot hole in the center of the bolt, be careful and get as near center as you can. Now you can re drill with a bigger bit and try a easy out.
Take your time and don't rush and get frustrated. Broken bolts can be tough sometimes but they can be gotten out.
Good Luck!
zackmorris
Reg: 04-05-12
04-07-12 10:39 AM - Post#2212393
In response to S10Fanatic
i tryed the screw extractor set, didnt work, so i went to tapping it and of course with my luck, the Tap broke off in the hole, now a machine shop is my only option im guessin...
TAT_2
"12th Year" Silver Supporting Member, and Official CT Grim Reaper
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
04-07-12 04:42 PM - Post#2212488
BUST OUT THE TAP,REMOVE,REDRILL & USE THIS OR EQUIVALENT
09 PONTIAC VIBE
08 PONTIAC G6
_-_-_-_-_-_-_-_-_-_-_-_-_ -_-_-
08/01/12 >>> B'CAME VETTE'LESS,
JUST LIKE JEFFREY
NEXT ?
Blessed are the cross-eyed, for they will see God twice |
