Username Post: 1996 chevy k1500 check engine light        (Topic#279086)
93chevyz71
Reg: 01-28-12
04-03-12 09:25 AM - Post#2210720
i got a 96 chevy 4.3 5 speed 4x4. im gettin a check engine light code p0154 02 sensor ck no activity (bank 2 sensor 1)
93chevyz71
Reg: 01-28-12
04-03-12 03:13 PM - Post#2210853
    In response to 93chevyz71
also just got a p0146 Oxygen Sensor Circuit No Activity (Bank 1, Sensor 3)
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
04-03-12 06:26 PM - Post#2210954
Sounds like you have two failed/failing O2 sensors. One in front of the cat and the other behind. I'm not up on OBD2 designations, but I'm guessing the bank 2 is the passenger side and bank 1 is driver side. Somebody hollar if I'm wrong.
If they're original, it's time to replace them all.
Greg
Greg
'00 Explorer XLT 4.0 V6 Auto
93chevyz71
Reg: 01-28-12
04-04-12 09:22 AM - Post#2211217
    In response to CowboyTrukr
also noticed today at 65 miles and hour and when you kinda lug it its got geark to it. can the o2 sensors cause that? and i noticed that wire that goes were the thermostate is some one has moved it to the ac compressor bolt.
350whip
350whip
Reg: 02-24-12
04-04-12 11:11 AM - Post#2211266
if your sensors are messed up lots of things can happen. switch them out go for a drive and post results of the switch.
RickT.
  • 1989 chevy k1500
  • regular cab, shortbox
  • chevy SB350tbi (little piggie!)
  • L60E Automatic 4speed
  • corvette servo
  • 30"BFG AT's
93chevyz71
Reg: 01-28-12
04-04-12 08:02 PM - Post#2211462
    In response to 350whip
ok ill let you all no the out come. when i get the money to replace them. a buddy of mine said he can hook it up to a computer and watch them he said the the one o2 sensor bad could calse a code for the other one. mine has 3
355Cheyenne
355Cheyenne
Loc: Northern MN
Reg: 10-27-04
04-05-12 07:25 AM - Post#2211596
That is messed up... This truck doesn't have a 3rd sensor. Only a bank 1/2 (driver/passenger) and sensor 1/2 (pre/post cat)
Not sure where to even start with that kind of problem.
98 Silverado k1500 4x4 350
93chevyz71
Reg: 01-28-12
04-05-12 03:29 PM - Post#2211747
    In response to 355Cheyenne
i looked at it my self. it has 2 before the cat and the on after
93chevyz71
Reg: 01-28-12
04-06-12 03:01 PM - Post#2212125
erased them codes and got a code p1153
93chevyz71
Reg: 01-28-12
04-06-12 07:34 PM - Post#2212215
also i noticed it smells like its burning rich on gas.
93chevyz71
Reg: 01-28-12
04-07-12 03:39 PM - Post#2212477
no help?
93chevyz71
Reg: 01-28-12
04-07-12 05:10 PM - Post#2212499
and it does have 4 o2 sensors. their is 3 before the converter and their one after it.
355Cheyenne
355Cheyenne
Loc: Northern MN
Reg: 10-27-04
04-07-12 07:06 PM - Post#2212529
Two before cat and two after. In 96 up they have two cats, one per bank. So each bank is handled separate. The first two o2 sensors are engine control sensors and are used for trim. The two after the cats are there purely to confirm the cats are functioning so they are emissions related. There isn't a 3rd in a bank. The OBD II code does accommodate for a 3rd in bank sensor and there are applications out there but not in the case of a 96 chevy vortec.
93chevyz71
Reg: 01-28-12
04-07-12 07:21 PM - Post#2212539
i got a 4.3 v6 not a v8. their is a sensor on each side just below the manifolds and their is on just before the cat so that makes 3 before the cat and their is one after the cat.
93chevyz71
Reg: 01-28-12
04-07-12 07:31 PM - Post#2212547
and mine only has one converter
355Cheyenne
355Cheyenne
Loc: Northern MN
Reg: 10-27-04
04-07-12 09:41 PM - Post#2212594
Aaah, I am sorry. I am so used to everything being v8 around here. Your post cat sensor is bad, lol that is all. Sorry.
93chevyz71
Reg: 01-28-12
04-08-12 05:56 PM - Post#2212876
i took and switched the bank 1 and bank 2 sensors s the bank 2 had a little carbon on it and i wiped it off with a towl and put it in i drove it around about all day and the light has not came back on yet and seems to run ok i noticed when its idels it has a slight like miss viberation i was told it was a 4.3 viberation issue common idk about that.
355Cheyenne
355Cheyenne
Loc: Northern MN
Reg: 10-27-04
04-08-12 06:39 PM - Post#2212899
That may work and that is fine I guess but IMHO I would say save up, it is time to put a little money into the old girl.
93chevyz71
Reg: 01-28-12
04-09-12 03:51 PM - Post#2213210
well i wanted to switch them around to make sure it wasnt a wiring problem or something else but the engine light came on this morning and i got a p1133. which is bank 1 sensor 1 with was the o2 sensor that i took out of the bank 2 that was showing bad. aslo is bosch o2 sensors any count? also i have also have had a p0146 Oxygen Sensor Circuit No Activity (Bank 1, Sensor 3) only had it to come on once. is that the sensor before the cat or after. their are 3 sensors total before the cat and 1 after. i takin it being 3 it has to be the one behind the cat. aslo my buddy said that were the on sensor is bad could be throwing the other sensor off. idk im not much of a mechanic.
355Cheyenne
355Cheyenne
Loc: Northern MN
Reg: 10-27-04
04-09-12 04:47 PM - Post#2213243
That last code is the post cat. So we know for sure you have two bad sensors. IMHO do them all and around here we generally steer clear from Bosch o2 sensors.
93chevyz71
Reg: 01-28-12
04-09-12 06:49 PM - Post#2213298
i heard the delph brands Only reads 4mV at key on, engine off. A correct application sensor like the AC Delco AFS65 or AFS75 (original and part that superseded it) will read 450mV. Starting an entire half volt too low will cause your PCM to start dumping fuel to each bank trying to correct what it sees as a super lean condition.
ckjurk
Reg: 05-23-12
05-28-12 10:11 PM - Post#2230970
Sounds more like you have a catalytic converter intermittently getting blocked up, would acount most likely for the odd o2 sensor readings
Nothing more satisfying than lying on your back in shorts and a t-shirt working on your truck...
1996 Vortec 5.7L K2500 PU
Execution time: 0.276 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:47 PM
