Username Post: Horn Switch        (Topic#278875)
Mark C 65SS
Mark C 65SS
Loc: Melbourne Australia
Reg: 01-20-12
03-30-12 03:53 AM - Post#2209077
Hi Guys trying to work out were the wiring goes on the horn switch, the parts seam tobe inside the stearing wheel but no wire connected, has anyone got any info, i've got the horn wire under the dash, but it dosent go anywhere ?
Any Help would be great
Edited by Mark C 65SS on 03-30-12 03:58 AM. Reason for edit: No reason given.
Allan In NE
Reg: 12-27-11
03-30-12 04:20 AM - Post#2209083
    In response to Mark C 65SS
The horn circuit is like the courtesy lights. It is a 'ground searching' deal.
Trigger wire from the horn relay comes up thru/in the turn signal switch wiring and grounds to the steering column when the switch is activated.
Allan
Lifelong GM automatic transmission specialist
Mark C 65SS
Mark C 65SS
Reg: 01-20-12
03-30-12 04:32 AM - Post#2209086
    In response to Allan In NE
Thanks Allan, do you know were it actually connects to the horn switch / diaphram ?
leon phelps
leon phelps
Loc: Croydon Manor, PA
Reg: 06-04-05
03-30-12 05:02 AM - Post#2209092
try the reference materials section.
Metallica Fuel
Edited by leon phelps on 03-30-12 05:02 AM. Reason for edit: No reason given.
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
03-30-12 07:15 AM - Post#2209141
there should be a round,spring loaded copper contact to which the wire connects. the copper contact rubs on the insulated belleville washer which is grounded when pressing the horn button.
look in parts catalogs. a lot of times ther will be a detailed assembly diagram or purchase a factory assembly manual.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
11 malibu (new)
03-30-12 08:37 AM - Post#2209169
Mark, here's a couple of pictures of the brass ring which activates the horn relay when the horn button is pressed (grounding the ring).
The reason a horn relay is used is because the horns draw too much current to be routed through the firewall and up to the steering wheel. The relay is mounted on the radiator support on the driver's side. Only the relay coil is triggered by the horn "switch".
These pictures are of the American AutoWire replacement turn signal switch. The black wire is the horn wire.
Mark C 65SS
Mark C 65SS
Reg: 01-20-12
04-01-12 04:47 PM - Post#2210028
    In response to 427SS65
Thanks Tom this was just what i was after, it looks like this is the part im missing from mine, i was struggling to workout were the wire connected on mine, Cheers Thanks again
Mark C 65SS
Mark C 65SS
Reg: 01-20-12
04-01-12 07:16 PM - Post#2210096
Hey Tom do you know were this part is mounted ? do i need to remove the steering wheel from coloum, i presume it's mounted around the indicator stork, but cant seam to find anything in the manual or reference sections.
04-01-12 10:03 PM - Post#2210151
Yes, remove the horn cap, then the nut. You might need a cheap wheel puller to get the steering wheel off. After the wheel is off, it will be painfully obvious where this switch is located!
Mark C 65SS
Mark C 65SS
Reg: 01-20-12
04-01-12 11:25 PM - Post#2210156
Thanks again Tom for your help, i'll let you know how i go Cheers Mark
Mark C 65SS
Mark C 65SS
Reg: 01-20-12
04-03-12 05:27 AM - Post#2210618
Hi Tom removed the steering wheel but cant see the peice you had in the photo " i think something is missing" i've taken a photo but cant seam to add it.
Cheers Mark
leon phelps
leon phelps
Reg: 06-04-05
04-03-12 08:40 AM - Post#2210704
https://picasaweb.google.com/humpydog/20111224?aut ...
try there. show step by step removal.
Metallica Fuel
04-03-12 08:48 PM - Post#2211016
Mark, at the 11 o'clock position of the switch in the photos, you'll see a square pocket with a hole in it. That is for the turn signal lever arm. It is held in place with a self tapping screw. If you don't have a turn signal arm, you don't have a switch.
Also, everything you see is one piece. If you are missing the brass ring, you need a new switch.
Mark C 65SS
Mark C 65SS
Reg: 01-20-12
04-04-12 06:47 PM - Post#2211421
    In response to leon phelps
Hi Leon,
Thanks for the effort & photos they are great, looks like mine might be missing the cancelling cam screwed to bottom of steering wheel photo 10, but the section onto of coloumn photo 11 is different, mine is metal & the indicator stalk screws into a tapped hole in this, then there is a flat metal spring on right hand side of metal section which i presumed was the self canceling spring but it may not be, it seams original but i'll keep looking to see if i can work it out, cheers again & thanks for your help Mark
Mark C 65SS
Mark C 65SS
Reg: 01-20-12
04-04-12 07:59 PM - Post#2211458
Guys hopefuuly you see the attached photos
https://picasaweb.google.com/lh/photo/m3LJzlb1qVoE ...
Edited by Mark C 65SS on 04-04-12 08:01 PM. Reason for edit: No reason given.
Mark C 65SS
Mark C 65SS
Reg: 01-20-12
04-04-12 08:05 PM - Post#2211464
https://picasaweb.google.com/115847506138413123800 ...
Edited by Mark C 65SS on 04-04-12 08:15 PM. Reason for edit: No reason given.
Mark C 65SS
Mark C 65SS
Reg: 01-20-12
04-04-12 08:37 PM - Post#2211477
Hi Tom thanks for you feedback & help, ive posted some photos now which should make it a bit clearer, i must have a different switch arrangement see what you think Cheers & thanks for your help Regards Mark
04-04-12 09:35 PM - Post#2211491
Exactly what year and kind of column is this? Looks like a tilt wheel column.
04-04-12 09:42 PM - Post#2211493
Mark, if you have a tilt column, which I believe you do, download this (which is in the Reference Materials area):
http://www.antechlabs.com/K0GFM/TiltWheelTraini ng....
Mark C 65SS
Mark C 65SS
Reg: 01-20-12
04-04-12 09:52 PM - Post#2211502
Hi Tom,
It's a 65SS impala with tilt steering coloumn, it has the delux interia package with Buckets,cloth inserts etc & i believe is the original coloumn
Mark C 65SS
Mark C 65SS
Reg: 01-20-12
04-04-12 10:01 PM - Post#2211509
Tom
I think your right on the money there,you know i looked at that previously & didnt think it was what i had but on closer inspection there is a section on Fig 4 (page 6) that shows a horn contact assembly it looks like this is what i need, not sure if there are repo's of this but well strip it tonight when i finish work, thanks Tom i owe you a beer if you ever get down to Oz cheers Mark
04-04-12 10:04 PM - Post#2211511
Gosh, I wish I'd known that was a tilt before I presented you the non-tilt turn signal switch!! No problem! Glad we got that straight...
Download my manual and it has a parts diagram in the training document. It shows you how to take it apart and re-assemble it.
That actuator plate with the springs drives a remote control mechanical cable down to a turn signal switch mounted outside the steering column (under the dash). The switches are available, but not the mechanical cable. You could probably make one out of a lawn mower throttle cable if you're missing that part.
Don't break anything, very few parts are available for it.
Glad to help out. GO SLOW - DON'T BREAK ANYTHING!
Execution time: 0.11 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:35 AM
