Username Post: Exhaust manifold bolts.        (Topic#278565)
350whip
350whip
Reg: 02-24-12
03-24-12 08:28 AM - Post#2206881
ok so i got some new headers for FREE... my question it what is the best way to get 23 year old exhaust manifold bolts out without breaking them. i have new bolts i just really don't want to drill tap and have to get bigger ones. i put a wrench on it after soaking the crap out of it with liquid wrench and tapping away for a 1/2 hour. no joy. the sucker is welded in i think. (i have broken enough bolts to know how hard not to turn lol)
RickT.
  • 1989 chevy k1500
  • regular cab, shortbox
  • chevy SB350tbi (little piggie!)
  • L60E Automatic 4speed
  • corvette servo
  • 30"BFG AT's
navygunner08
navygunner08
Loc: New London, CT
Reg: 02-13-11
03-24-12 08:40 AM - Post#2206886
    In response to 350whip
Do you have a small buetain torch? You can try heating it up like that.
1994 K1500 Z-71
350whip
350whip
Reg: 02-24-12
03-24-12 08:43 AM - Post#2206889
    In response to navygunner08
good idea i will try that when i get home.
RickT.
  • 1989 chevy k1500
  • corvette servo
  • 30"BFG AT's
Allan In NE
Reg: 12-27-11
03-24-12 09:03 AM - Post#2206897
Sell the bubble-gum headers and make a buck?
Allan
Lifelong GM automatic transmission specialist
markss
Loc: Palm Beach County, Fl
Reg: 12-02-11
03-24-12 09:08 AM - Post#2206902
Try shocking them. No, I don't mean show them porn! Put a boxed end wrench on the bolt, put some pressure on it and smack the bolt head with a hammer. Works best with two people. If the wrench is deeper than the bolt head, you will have to grind it off enough to show a little bit of the head.
Good luck, Mark
350whip
350whip
Reg: 02-24-12
03-24-12 09:33 AM - Post#2206912
    In response to Allan In NE
naa... I'm going to throw $$$ at this truck until i die lol the bodywork is all done over the next year or so im going to get a bunch of bolt on crap anyway the suckers are brand new not some rusty crap of a junk truck selling them would'nt be worth it cause i will end up getting them later anyway. im going to try all the tricks posted and if i still think i will break em i will just hold off putting them on until I redo the intake then i will have a week to deal with all the crap i break.
RickT.
  • 1989 chevy k1500
  • corvette servo
  • 30"BFG AT's
350whip
350whip
Reg: 02-24-12
03-24-12 09:35 AM - Post#2206913
    In response to markss
ya i made a "custom" socket for this that's how i was beating in the liquid wrench.
RickT.
  • 1989 chevy k1500
  • corvette servo
  • 30"BFG AT's
jham0077
Loc: Greenville, Il.
Reg: 11-04-11
03-26-12 06:41 AM - Post#2207596
I have seen someone go as far as grinding all the heads off, sliding the manifolds off the studs, then just having the studs to deal with. But it was on a rebuild on a stand(slightly easier to get to). Then you can heat the block around the bolts where it really counts. I got one broke off and was wondering about gettin a bit that fits snug in the manifold and drilling the rough broken surface down smooth so I can use a smaller bit for my 'easy-out' hole. Then pray the others come loose so I can replace the gasket. If they're cheap headers, you may regret putting them on.
Keep throwing money at it, it'll get better...
95 Tahoe 5.7 w/5 spd
Gone but not forgotten,
87 LWB 4x4 5.0 w/3 spd granny,
84 SWB 4x4 5.7 w/3 spd granny,
93 Full Size Blazer 5.7 w/5 spd,
97 Step-side Vortec w/5 spd.
I like shifting gears.
Execution time: 0.177 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:49 AM
