ozdog210
Loc: Lowell, MA
Reg: 02-06-05
03-20-12 04:57 PM - Post#2205267
Hello again Gentlemen!
I just found out today that I will be needing to replace my front wheel bearings!(thats been the reason for the ABS kicking on at low speed!) So I wanted to stop in to ask....
1. Is it worth it to rip it all apart to simply replace the bearing? Or would it make more sense to just do the entire hub assembly while I'm at it?
2. Does anyone have a link to any threads or websites with a good step-by-step procedure for getting this done?
Thanks for your help!
| 1997 K1500 Suburban FULLY LOADED!! |
hawkeyes
Loc: IOWA
Reg: 11-05-09
03-20-12 08:01 PM - Post#2205375
In response to ozdog210
If it is 4 wheel drive you can only replace as a hub assembly only . mark
90 3/4 ton extcab long box 350 4speed 4.10 gears
420-443 lift cam headers
delta flow 40 mufflers
edelbrock tbi intake custom tbi spacer
custom cowl induction air cleaner
msd6a msd coil 275 70 18 dura grappler
bosch platinum+2 plugs |
Lead sled
Loc: WALTON,NY.
Reg: 11-04-09
03-20-12 08:29 PM - Post#2205397
In response to hawkeyes
I just took the fuse out for the anti-lock crap brakes...Who needs them,they never work right anyway.Pump the brake pedal if you're afraid of a skid.Just like we drove BEFORE all this computerized garbage came about.
51 BelAir 2drht 52 trim.Basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405,Saginaw 4spd/355 geared 55/6 Chevy rear.I just finished all the bodywork/paint myself.2,1st place trophies so far
http://www.picturetrail.com/bris51deluxe
TwentyBucks
Loc: Cape Cod, MA
Reg: 11-06-07
03-21-12 09:34 AM - Post#2205538
Check Youtube, there are some pretty good step by step procedures posted there. I used one when I replaced both front wheel bearing assemblies on my 03 Suburban.
2010 Cadillac CTS
2003 Suburban 4X4
98 K1500 5.0L
2002 Honda Civic, commuter car |
evhfan2000
Loc: Portland, OR.
Reg: 10-17-04
03-21-12 07:44 PM - Post#2205881
I replaced both fronts a few months back. Got a pretty good deal from rockauto.com. Timken brand. Make sure you are buying American made, not the cheapos from EBay. They are are going to run $160+. Anything significantly cheaper is going to be junk.
Dean
65 Impala Sport Coupe
99 CK2500 4x4 7.4L Crew
03 CK1500 4x4 5.3L Sub
02 CR250R |
