Username Post: Lifting the Rear End of a Belair        (Topic#277268)
19554drbelair
19554drbelair
Loc: ON, Canada
Reg: 05-06-09
03-01-12 08:03 PM - Post#2197327
I am thinking about putting a body lift or suspension lift, maybe 2", to get that slanted hot rod look on my 55. However the back end already has some modifications that I don't know what they are. I don't have the photos with me, but i have this crude drawing:
The bumpers on the bar do have a decent amount of space between them and the springs, i just cant draw that well.
So any ideas on the lift of the rear end or what those bars are for?
I know it would be easier to drop the front end, but i dont want to give up the stock clearence as i hit the back (dirt) roads a fair bit.
SAM_57
SAM_57
Loc: SE VA USA
Reg: 06-20-01
03-02-12 04:22 AM - Post#2197398
    In response to 19554drbelair
I have no idea as to what the drawing is of. Pictures are the best.
S.Pollard 57 Belair sport coupe 69 C/10 stepside (wife's) 84 Monte Carlo SS
retiredrich
retiredrich
Loc: NE
Reg: 10-05-07
03-02-12 05:27 AM - Post#2197411
    In response to SAM_57
Interesting drawing. Maybe the circle is the tire and traction bars are sticking out both sides and the dark part is the leaf spring? The dark line up on top might be the trunk open........
03-02-12 05:28 AM - Post#2197413
The drawing looks like traction bars, but they would normally only face forward and have one snubber. They are to stop the springs from wrapping up into an s shape and causing wheel hop and to stop the rear end from rotating upwards on acceleration to improve traction. If that's what they are, they have nothing to do with ride height.
The easiest way to raise the rear would be with air shocks. But if you don't have a shock bar in the rear and the shocks are mounted to the trunk floor as they were from the factory, you'll soon beat the mounts out of the floor with air shocks. They only other way I know of for leaf springs would be to get longer shackles for the springs.
03-02-12 07:34 AM - Post#2197437
    In response to wagonman100
I think they may be slapper bars. If you don't do any drag racing, remove them and have the springs re-arched. A spring shop will raise it as much as you want. That will raise it without affecting the ride like air shocks. The cheap way is longer shackles but they will cause rear end sway.
gotta56forme
gotta56forme
Reg: 09-19-03
03-02-12 08:17 AM - Post#2197449
    In response to acardon
If your car is at or near stock ride height another way to accomplish getting a rake would be to do 2" drop spindles on the front, or whack the front springs one coil.
I bought my 210 HT with really saggy four leafs in the back. My car sat lower in the back than some guys who had used lowering blocks on their car to drop the ride height. One of the guys in my car club gave me a set of fairly fresh 5-leaf springs he took off his '57 he was redoing. Brought the back end up quite a bit but not too much. Also firmed up the ride some.
To my eye, these cars look a little nose high in the original advertising photos. If your car still retains it's stock stance, I can see why you might want to lift the rear end to get a cooler 'rake'.
Scott/Gotta56forme
Fishermark
Fishermark
Loc: Pt Charlotte, Florida
Reg: 01-04-01
03-02-12 11:53 AM - Post#2197526
    In response to gotta56forme
When I bought my car in 1976, the "cool" thing to do what to raise the back end and put wider tires underneath. The cheap and easy way we did it back then was to remove the original shackles and install longer shackles. These were simply made of heavy flat stock. I had my car like that for many years!
1956 Chevy Bel Air 2 dr sedan
Pics of my car
Execution time: 0.588 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:33 PM
