Username Post: I need some front end HELP!        (Topic#276006)
karrz
Reg: 12-21-10
02-06-12 06:16 AM - Post#2187723
I have owned my 62 Corvette 327/340 for over 32 years. I was told my kingpins were worn and needed to be replaced. While i was away on business my father had a friend of his replace the kingpins.I wasn't happy about it. Now when i drive the car the front shimmys like crazy when I hit 30MPH.The steering wheel wobbles about 10 degrees . I took it to a frontend guy and he said the front end was okay.Could the steering box need to be rebuilt/adjusted? Or how can I check the frontend myself to see if the friend messed up Thanks
"13th Year" Platinum Supporting Member & Moderator
02-06-12 07:57 AM - Post#2187761
    In response to karrz
I imagine the pins are not fitted correctly into the bushings. Probably a sloppy fit!
wagonmaster
wagonmaster
Loc: Loganville, Ga.
Reg: 04-28-00
02-06-12 11:36 AM - Post#2187822
    In response to 427SS65
Did you get it re-aligned after the king pin job?? Might check that...
Hey T @!
Joe
karrz
Reg: 12-21-10
02-06-12 05:25 PM - Post#2187955
Thanks, how can i check the fit? The guy that aligned the front end said everything was good. But not sure what he checked
karrz
Reg: 12-21-10
02-06-12 05:27 PM - Post#2187957
    In response to wagonmaster
Yup I had it aligned and the service guy said all was well. Thats what puzzles me
02-06-12 06:25 PM - Post#2187987
That's a classic sign that the king pins are worn out - when the wheels flip flop (shimmy). New king pin and their associated bearings (bronze or ball) are machined as a set.
The bronze ones are reamed with a pin reamer to match the O.D. of the pin (plus an excess amount to allow the pin to turn without binding).
Something is wrong with the work done to the car. Take it to someone who specializes in king pins to get a second opinion.
wagonmaster
wagonmaster
Reg: 04-28-00
02-06-12 08:12 PM - Post#2188021
The only thing I can figure (sight unseen) is that the axle may be worn and the kingpin holes could be worn beyond tolerance or "eggshaped". You can bush the axle to correct this, if that is indeed the case.....Sold a '58 pickup that was wrecked to a guy that had a '57 with a bad axle (my front axle had new pins and bushings, brakes, etc.....) That fixed his problem!
Hey T @!
Joe
02-07-12 06:05 AM - Post#2188104
I thought it was standard procedure to rebush on all kingpin replacements? How could the bushing not be worn if the pin is worn? I think the pin is hardened steel and the bushing is only a lubricated bronze material. I watched a professional do my Dad's 58 Chevy Apache that had kingpins. He worked real hard - and so was the steering!
wagonmaster
wagonmaster
Reg: 04-28-00
02-08-12 01:18 PM - Post#2188567
Tom,
I'm not speaking of the bushing, but the axle itself.....If the axle is worn beyond specs, the bushings won't help all that much....The hole will need to be machined and fitted with a sleeve so that the king pin and bushings can provide the fit that is necessary.
Hey T @!
Joe
02-15-12 09:46 AM - Post#2190908
OK, Joe! I guess we were thinking of the same part. I've never seen an axle worn. Usually the bushing (or the Moog replacement bearing) is all it takes.
How could the axle get that worn?
WagonMan
WagonMan
Loc: Las Vegas, NV
Reg: 10-26-04
02-15-12 11:53 AM - Post#2190948
Have you ruled out that the tires are out of balance also as well as the rest of the steering linkage?
Charles
57 210 4dr. Wagon(bought '82)
-350/700r4 Mild Custom
56 BA 4dr. ht.(bought '98)
-265/TH350 Mostly Stock
29 Ford Sedan(bought '75)
-4.3L/TH350(in progress)
wagonmaster
wagonmaster
Reg: 04-28-00
02-15-12 03:02 PM - Post#2191010
I sold the front axle off of my wrecked 1958 Chevy p/u to a guy that had a '57 with terribly worn king pin holes. Lack of lubrication advances the wear of those components dramatically!! The trucks are usually much worse than the Corvettes, because we take/took a little better care than some truck owners did, especially back in the day.
Hey T @!
Joe
TAT_2
"16th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
02-21-12 03:32 PM - Post#2193501
GOOD READ ,WITH PICS,FROM 1 OF OUR OWN
IM MORE AKIN TO BUS & TRUCK KING PINS,BEEN OUT FOR AWHILE BUT WE DONT EVEN REBUSH,WE USE A SPIRAL WOUND SPRING INSTALLED WITH T HANDLE,THEN BREAK OFF THE TAB.
09 PONTIAC- VIBE
08 PONTIAC- G6
96 FURD SUPER CAB XLT 4X4
NEXT ?
Hugomiller
Loc: Florida and UK
Reg: 05-02-17
12-02-17 02:38 AM - Post#2716620
Don't rule out bizarre co-incidences. The first thing I would try is to swap the wheels front to back. It might be possible that the guy who did the work road-tested it & hit a kerb. Or maybe one of the tires chose that precise moment to develop a bulge or other irregularity that would throw it out of balance.
Then just check everything for play - king pins; steering joints; shock absorbers & bushings - everything.
There are only so many things it can be, so shouldn't be hard to find with a methodical approach and an open mind. Don't just assume it must be because of the king pin work that's been done - strange things do happen!
Execution time: 0.246 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:45 PM
