Username Post: how much paint for frame        (Topic#273736)
lamothe1
lamothe1
Loc: cypress, ca us
Reg: 03-13-02
12-19-11 11:47 AM - Post#2170326
How much paint should I purchase to paint the frame of my "35 Chevy after it's sandblasted. It's about 98 s.f. of area. I’m going to use polyurethane or is POR15 more durable?
Edited by lamothe1 on 12-19-11 11:55 AM. Reason for edit: No reason given.
Vaughn
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
12-26-11 12:17 PM - Post#2172509
    In response to lamothe1
It varies widely. It depends on how many coats you do, and what product you use. It also depends on the frame.
POR15 will usually take up to 3 quarts - if you do it all at once. IF you try to do it in spurts, it will take more because once you open a can of it, it usually goes bad unless you REALLY seal it properly.
Poly - it will depend on how many coats you do.
convman1960
Infrequent Contributer
Loc: Kansas city Kans
Reg: 07-25-10
06-28-17 04:14 PM - Post#2697906
    In response to Vaughn
when i use por 15 i never open the lid, instead i put a hole in the lid and pour it from there, then i clean the area around the hole and use electrical tape over the hole, it lasts a long time, it does take longer to put the paint in a cup but it does last longer
65_Impala
Reg: 12-29-02
06-28-17 08:36 PM - Post#2697960
I wouldn't POR15 it. Use quality automotive paint products and you'll be much further ahead. If you're spraying it in a gun and doing the suspension parts too I would think maybe 1/2 a gallon.
KShortell
KShortell
Loc: Chesapeake, VA, U.S.A.
Reg: 04-14-01
07-03-17 06:52 PM - Post#2698618
    In response to 65_Impala
I just use an epoxy enamel on frames and have had really good results.
Eastwood's internal frame coating and wand/snake thingy are really good, too. Best of all, it can be cleaned out and reused for most paints.
Semper Paratus
FL05-03 Home Page
Stock is not a dirty word...
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
07-04-17 06:02 AM - Post#2698667
    In response to KShortell
I cleaned -power washed my frame and then used some wax grease remover and shot it with some chassis saver paint = 2 qts .Done this on my 63 Impala paint turned out great and pretty durable
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327
Execution time: 0.286 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:17 AM
