Username Post: 1966 Bel Air Starting Problem        (Topic#268736)
Shanester
Shanester
Loc: Oregon
Reg: 11-21-10
09-05-11 12:00 PM - Post#2133982
Alright guys...I use to start it with the key..but now I can't...switched Ignition switches...and starters...still have the problem..I ran wires from the starter to "hot wire" it and jump them to get it started..Key has power..I think I have a broken wire somewhere?.....any help?...Shane
Shane
1964 Cadillac Sedan De Ville
1965 Impala SS
1966 Impala 2 door hard top
1966 Bel Air 2 door Post
1965 Impala 2 door hard top (parts car)
1966 Biscayne 4 door (parts car)
100 CHEVY
100 CHEVY
Loc: Helena,Missippi,U.S.A.
Reg: 12-09-04
09-05-11 01:20 PM - Post#2134010
    In response to Shanester
Check the bulkhead connector under the wiper motor.It may need cleaning.See if the ignition sends power to that point.If you have power here,the problem is from here to the starter.If no power to here from the ignition,it's from the connector to the ignition switch.
I just put a new (rebuilt) starter on my 65 yesterday.Bad soleniod.
Mike.
09-05-11 01:21 PM - Post#2134011
Does the engine not turn over or does it crank but not start? Is it an automatic transmission? A neutral safety switch will keep it from cranking and the firewall plug can keep it from starting or cranking.
Shanester
Shanester
Loc: Oregon
Reg: 11-21-10
09-05-11 01:30 PM - Post#2134016
    In response to 100 CHEVY
Thanks for the reply Mike..I'll check
Shane
1965 Impala SS
Shanester
Shanester
Loc: Oregon
Reg: 11-21-10
09-05-11 01:35 PM - Post#2134017
    In response to acardon
aaah yes Don it doesn't turn over...and it is all factory 283 Powerglide...I just downloaded the wiring schematic diagram for it..and see I could have a Neutral Safety Switch issue
Shane
1965 Impala SS
Shanester
Shanester
Loc: Oregon
Reg: 11-21-10
09-05-11 01:59 PM - Post#2134032
GOT IT!...bad connection at the Neutral Safety Switch!
Shane
1965 Impala SS
HAL_396
HAL_396
Loc: Austin, TX
Reg: 11-16-06
09-10-11 02:27 AM - Post#2135800
Good job!
1955 Chevy Custom
1966 Biscayne
1966 Caprice Drag Car Inwork
1966 Caprice parts car
Execution time: 0.377 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:41 PM
