Username Post: Building a torque monster 350        (Topic#268475)
CowboyCadillac
Reg: 08-30-11
08-30-11 02:57 PM - Post#2131945
Howdy guys. I am coming here looking for help. I want to build a beasty little 350. Mainly for use in truck pulls around here called 'Local Yokal' pulls. The ruck is a K10, getting a 8 lug swap up front and a 3/4 rear end in the back. I am going to do the truck up to be very streetable and a great sled puller. I am not looking for full pull but I want to be pulling just as good as the BB guys. Now break me in easy here guys I am a FORD guy ll this is just a fun little side project. Also IDK if it is possible but I want a bad censored sounding idle. But if you guys would mind me giving me some ideas for my setup, I would appreciate it.
Senior Chevytalk Moderator
08-30-11 04:36 PM - Post#2132003
    In response to CowboyCadillac
Welcome to the site. I'm moving your engine post to the performance section. The Performance section users will offer tons of information to build a torque monster. Torque and power are based on how much you want to drain your bank account.
Post another topic on drivetrain options and suggestions.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
08-30-11 04:50 PM - Post#2132009
the only reasonable way to make a 350 sbc outperform a big block 454 -572 big block with easily 100 or more cubic inches of displacement is if you use a supercharger or something like turbos or nitrous
yes you can build a 450-500hp small block, but in truck pulls a decent big block can have more than 600-800ft lbs of torque, your not going to get a sbc 350 to beat that without a power adder like a supercharger
Edited by grumpyvette on 08-30-11 04:53 PM. Reason for edit: No reason given.
CowboyCadillac
Reg: 08-30-11
08-30-11 06:19 PM - Post#2132054
    In response to grumpyvette
Very sorry Gchemist, and I appreciate you moving it for me. And its a street class. So alot of the BB Ford and Chevy guys are running stock engines. I know the Ford guys are cause I know each and every one of them and I know there engines. As for a power adder I thought about a centrifugal supercharger, but thats something I can add down the road. I have Desktop Dyno which is good for most things, so I get a idea of how my application will work and I find a Comp Cams thumpr cam (600 part number), a good Dual plane intake (Or some single plane) Intake running 1.6 intake rockers and 1.5 exhaust rockers, and 650 or so CFM carb. I get a max TQ of like 425 with max HP being around 380. Which I dont think is bad, but I want your guys opinions. The truck is going to driven ont he road, and some medium duty 4X4 use (Pull the tractor out when it get stuck, steep driveways in winter, etc) and Sled Pulling. So all suggestions I am open too. Now I want to add its a 4spd SM465, and from what I been told and from reading its hard to find a stroker kit that will allow me to run a manual tranny.
THANKS GUYS!
Vaughn
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
08-30-11 06:29 PM - Post#2132057
IF you want a torque monster, you are swapping in the wrong motor.
If you want a cheap junkyard motor that has a lot of torque - stock - then swap in a Cadillac 472-500. This will produce the torque (550-600 ft lbs) you are looking for without spending a lot of money. Use a conversion plate to swap the motor in place of the chevy bolt pattern at the trans, you will also have to build motor mounts for it.
There are lots of these motors in the junkyard that are still in good running condition (don't get stuck on the 500, the 472 is just as good and are much more plentiful). If you can't find a Cadillac, you can also look for a buick or pontiac 455, these have fairly good torque also.
The Cadillac weighs about the same as a small block (about 50 lbs more) when installed. It also gets about the same gas mileage as the small block chevy does.
You can get a cam for a lopey idle, if that is what you want. Edelbrock carries an aluminum intake for this motor also.
dcairns
dcairns
Loc: Orange CA
Reg: 11-07-03
08-30-11 06:51 PM - Post#2132067
    In response to Vaughn
You can bore and stroke a 350 to a 383. That will help some with the displacement disadvantage.
- Dave
1964 Impala 4-door sedan
_________
_/ /___________\ \_
/_________|_________\
|OOO ___________ OOO|
\______|====|______/
|_|------------------|_|
CowboyCadillac
Reg: 08-30-11
08-30-11 07:27 PM - Post#2132081
    In response to dcairns
I was told to look for one of the old caddy motors but where I live finding one of those is like me finding gold bricks in my garage, dont happen. I have thought about making it a 383, but like I stated I am under the impression its hard to find stroker kits that will allow you to use your manual trans. I want to find a 396, I think it would be fun and interesting in a truck.
08-30-11 07:36 PM - Post#2132087
I vote Caddy!!
http://www.500cid.com/
busterrm
busterrm
Loc: Wichita Falls, Tx
Reg: 08-31-10
08-31-11 06:07 AM - Post#2132183
My opinion is to go with a stroker, building a stroker for a manual tranny is not a hard thing to do. Just as building one for auto, you just have to plan all the components, cam, heads, ignition, intake, carburetion, and having a good tune will give you a strong torque monster.
==== BOB ====
If I can't smoke the tires I want more!
1976 Chevy Nova
2007 Chevy 1500 1/2 ton
2008 Harley Davidson XL1200 Sportster
55 Shaker
Loc: north central IL.
Reg: 03-13-06
08-31-11 07:51 AM - Post#2132213
The only replacement for cubic inches is "RECTANGULAR DOLLAR$$$$$"
CowboyCadillac
Reg: 08-30-11
08-31-11 01:34 PM - Post#2132294
    In response to 55 Shaker
Shaker that was priceless. And as for a stroker, I may. I am mainly looing for cam suggestions and such.
dcairns
dcairns
Loc: Orange CA
Reg: 11-07-03
08-31-11 02:07 PM - Post#2132305
You might want to invest in the book
"How to Build Big-Inch Chevy Small Blocks" by Graham Hansen.
http://www.amazon.com/Build-Big-Inch-Chevy- Blocks-...
The possibilities of boring and stroking small blocks is explored as well as aftermarket blocks that can get you up to 454 cubic inches in a 'small block'. Of course all that gets expensive But I think you will find the 'recipes' in the back of the book interesting. They have specs and dyno results of some varied builds. Some built for street use, torque monster, high rpm horsepower, etc
- Dave
_________
_/ /___________\ \_
CowboyCadillac
Reg: 08-30-11
08-31-11 06:16 PM - Post#2132360
I had remembered seeing that book and I am going to go to the library tomorrow (Which is right down from me shop) and see if they have it, and the book about rebuilding/modifying Quadrajets.
IgnitionMan
Reg: 04-15-05
08-31-11 06:43 PM - Post#2132368
Unfortunately, for the mundane tow truck engines like the 350, the ONLY way to make torque is to go with a 400 crank in that engine, creating the 383 through 388 size. Anything else just isn't going to work as well as the additional stroke.
CowboyCadillac
Reg: 08-30-11
08-31-11 07:35 PM - Post#2132387
    In response to IgnitionMan
I have heard about this but it was never explained out. Just a 400 crank with 350 rods and pistons? Or whats the combination. Cause I want to build this engine out of stock parts.
busterrm
busterrm
Reg: 08-31-10
09-01-11 07:55 PM - Post#2132781
If you build a stroker, you will have to buy pistons with the 383 compression heighth. Stock 350 is 1.56, for a 383 it is 1.42. That is if you use 5.7 rods. That would be the only thing not OEM parts. But like said before, there is no replacement for cubic inches.
==== BOB ====
1976 Chevy Nova
fritz1990
fritz1990
Loc: Kansas
Reg: 02-16-03
09-02-11 05:40 AM - Post#2132854
    In response to busterrm
You can build a 383 with 400 crank and the stock 400 rods (5.565 length) and use stock 350 pistons.
Regards, Jeff
1998 K1500 6.5 Coal burner
1965 C10 with 498 BBC AFR Heads
1964 C10 Ran 348W for 6 years, now SBC.
Corvettes owned: '74 '77 '78 L82 Silver Anniversary, 2002 LS1
Don't have a nervous come together!
http://picasaweb.google.com/fritz199090
busterrm
busterrm
Reg: 08-31-10
09-02-11 06:15 PM - Post#2133074
    In response to fritz1990
Regards, Jeff
Sorry about that man, I am not a SBC 400 guru. I didn't know that 400 used that rod. I just did the math, and Jeff is exactly right, that will give you the stock deck clearance of 25.
==== BOB ====
1976 Chevy Nova
Edited by busterrm on 09-02-11 06:25 PM. Reason for edit: No reason given.
CowboyCadillac
Reg: 08-30-11
09-03-11 09:53 AM - Post#2133258
So what exactly is all the machining I would need to do to be able to run a 400 crank and rods with 30 over 350 pistons? Just wondering cause I want to gather parts as soon as I can so I can build this engine up nicely.
fritz1990
fritz1990
Loc: Kansas
Reg: 02-16-03
09-03-11 11:32 AM - Post#2133287
Been a long time since I done a 383 but the rod bolt nuts will hit the cam so some clearancing is needed on them. I think a few hit the pan rail also. Not a big deal to do just time consuming. Not sure if any hit the piston skirts but need to look here also. Turn it over real slooooooooooooow and gentle. Only need about .040 clearance on everything which is about the thickness of a larger wire tie.
Put 1 rod and piston in a hole and turn it over and use a wire tie for clearance. Grind carefully where needed and proceed to the next cylinder. Make sure the oil pump you are going to use is in place when you get to the back sets of rods.
Have to reclean everything after your done.
Regards, Jeff
Edited by fritz1990 on 09-03-11 11:33 AM. Reason for edit: No reason given.
CowboyCadillac
Reg: 08-30-11
09-03-11 01:10 PM - Post#2133304
Regards, Jeff
I want to ask about the rod bolts for clearing the cam, could you show me a picture for what I am shooting for? Also would I be able to get away with using a bur to do all my clearance work? And I got a question. I have read on a few other forums where guys have used ProComp aaluminum heads, they buy them bare then put there own valves and springs and such in them, and not have any problems (They also get the ported and such which I can do myself) But has anyone on here done it or is there a thread I could read aboyt peoples experience dong what I mentioned? And I want to thank you guys a bunch!
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
09-03-11 05:18 PM - Post#2133376
read thru these threads and sub links
CowboyCadillac
Reg: 08-30-11
09-04-11 08:42 AM - Post#2133558
Thanks Grumpy but there broken.... So can't read them lol
busterrm
busterrm
Reg: 08-31-10
09-04-11 09:46 AM - Post#2133577
If you get a 400 crank, you'll have to have the mains turned down to 350 mains ( 400=2.65, 350=2.45), make sure its not one of the 68 350s that had 2.3 mains. For the most part 350s are 2.45. Have the rod journals checked and resized to true the up. Also have the entire crank checked for straightness. Then last have it balanced as close as possible, but with a 400 crank you'll have to run a 400 balancer and flexplate(flywheel).
==== BOB ====
1976 Chevy Nova
CowboyCadillac
Reg: 08-30-11
09-04-11 06:10 PM - Post#2133714
I know they make a weight things you bolt on with your flywheel so you can runt he lighter 350 Flywheel on a 400. Anyways. I really appreciate all your guys help, and I hope to keep you guys informed.
dcairns
dcairns
Loc: Orange CA
Reg: 11-07-03
09-05-11 04:42 PM - Post#2134119
I don't think anybody uses 400 cranks anymore, they are too scarce. There are whole kits made to do up a 383, cranks pistons, rods, etc. Do a google search on "383 stroker kit". Some come setup to be internally balanced so you don't need the counterbalanced harmonic balancer and flex plate. But even with a 'balanced' kit, your machinist will need to balance things. Just less to do with a kit that is close to balanced already.
383ci Chevy Small BLock Engine Build
From Chevy 350 to Ground-Pounding 383 Stroker
How to Prep the Block, Which Parts You Need, and Why a Stroker
383 Stroker FAQ
- Dave
_________
_/ /___________\ \_
fritz1990
fritz1990
Loc: Kansas
Reg: 02-16-03
09-05-11 07:20 PM - Post#2134190
Last 383 I built was using a 400 crank as there were no kits for it back then.
As said use a kit and save yourself some money and hassle, and do go with the internal balance set up.
Regards, Jeff
Execution time: 0.251 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:16 PM
