Username Post: 91 R3500 350 TBI dual tanks No Fuel        (Topic#268402)
jaymes
Reg: 08-28-11
08-29-11 11:08 AM - Post#2131450
1991 R3500 with a 350 and 400something trans. running TBI. 350k mi.
symptoms: it always had a cold start stalling issue, to my knowledge it's never actually stalled. well yesterday i didn't gas enough through it and it almost fell on it's face. Then something new happened. On the 5 mile drive into town, driving at low rpms, it was missing every second or so. When I came to a stop in a parking lot, it stalled. started it back up fine, once in drive it would slowly stall unless I got on the gas or blipped in neutral then drive. Parked for 10 minutes, drove another mile to get gas, it has maybe 1/16th above empty, I put in 3 gal. Drove a half mile, parked, came back out maybe 20 minutes later and it wasn't firing at all. the carb was looking really dry, so i assumed it wasn't getting fuel, hopefully the filter is clogged. went to a parts store for starting fluid and a fuel filter. sprayed a shot into the carb and it fired, so no fuel for sure. got the used filter off to find it filled with rusty gas. Put the new one on and still no start. The fuses look good, the relay is good. It seems odd to me that both pumps would die at the same time, although I can't hear them prime. that's where I'm at right now, just looking for some insight before I take it somewhere
jaymes
Reg: 08-28-11
08-29-11 11:41 AM - Post#2131460
    In response to jaymes
well i just went out and unhooked the lines after the diverter valve and the pumps definitely work, at least in the left tank, 'cause fuel poured out upon turning the key. Now is it possible the line up to the throttle body is clogged? or something in the carb, sprayers?
Also, I don't know if this is relevant, but the fuel filters that I've had to change in the past, have sprayed fuel, there was no pressure when I swapped this one.
drifterdude
Reg: 09-04-08
08-29-11 12:15 PM - Post#2131473
You may not get much spray changing the filter as the TBI uses low fuel pressure compared to most other fuel injection systems.
As far as no fuel if the pump is working try to hook up a pressure tester and get us a reading it will help clarify if your pressure is up to par or not.
Also it could be the pressure regulator going bad but before we assume anything or throw parts try to get us a pressure reading.
92 K1500:350 bored 30 over,built 700r4,Comp extreme energy cam,double roller timing set,shaved heads,Rancho RS9000XL series shocks with wireless my ride system,35 inch Mickey Thompson Baja Claws,Relocated 4x4 switch to rocker on Dash.
Other mods..
jaymes
Reg: 08-28-11
08-29-11 03:43 PM - Post#2131537
    In response to drifterdude
oooooo, I'll have to find a gauge then.
pic for clicks in the meantime.
jaymes
Reg: 08-28-11
09-02-11 07:36 PM - Post#2133100
still haven't tested the pressure, but upon removing the ignition module, it's connectors were beyond rusted. replaced that with a new cap and rotor, still no start. just now used a test light on the wire from the coil to the distributor cap and there's no power. bad coil? or do i have to have someone turn the key on to get power from that.
jaymes
Reg: 08-28-11
09-05-11 03:10 PM - Post#2134067
well upon finding out that the distributor may be the culprit as it sends a signal for the injectors, found it to be very sloppy. swapped in a rebuilt unit and it runs!
drifterdude
Reg: 09-04-08
09-05-11 03:26 PM - Post#2134073
sounds like it was the ignition module in the distributer was shot then. Though if the dizzy was sloppy replacing the whole thing was not a bad thing at all. Glad to hear you got it going. Thanks for letting us know.
Other mods..
Edited by drifterdude on 09-05-11 03:27 PM. Reason for edit: No reason given.
jaymes
Reg: 08-28-11
09-07-11 11:59 AM - Post#2134834
so, am I supposed to run the engine with the ecm wire unplugged? I just unplugged it, plugged back in, disconnected/reconnected the battery and it still hesitates under load.
jaymes
Reg: 08-28-11
09-07-11 03:24 PM - Post#2134881
so, unhook tan/white connector, adjust dist., shut off engine, reconnect tan/white connector, and unhook/rehook battery? i'll have to try without a timing light later. i'm assuming it'll need retarding.
jaymes
Reg: 08-28-11
09-07-11 10:31 PM - Post#2135045
runs great now
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
09-11-11 09:23 PM - Post#2136376
What did you end up finding that fixed things?
Glad to hear it's working.
Your earlier question about running it with the timing signal disconnected is not advisable.
Greg
Greg
'00 Explorer XLT 4.0 V6 Auto
Execution time: 0.221 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:07 AM
