Username Post: 89 Chevy Van G20 Won't run, no spark. Need help.        (Topic#268202)
Froadinman
Reg: 08-24-11
08-24-11 09:19 PM - Post#2129954
I have a 1989 Chevy Van 20 (G20). Just yesterday I was driving down my street, stopped at the stop sign and it stalled as though out of gas. Tried to turn it back over with no luck.
I removed the dog house and the air filter housing, wanting to check if the injectors were shooting gas. The van briefly started and ran for about 10 seconds then stalled again and hasn't started again. The injectors are working. I did the old paper clip in the diagnostic port and got a 12 code for as long as the ignition was on acc.
Today I checked to see if I had a spark at the plugs, I didn't. Tried off the coil, there was no spark. I replaced the coil thinking that was it but still no spark or start. I still got a 12 code from the OBD.
08-25-11 05:16 AM - Post#2130027
    In response to Froadinman
Welcome to the forum,
The main suspect is your ignition module in the distributor. Could also be the pickup coil, but the module is more likely. Check our FAQ post at the top of this forum listing for more info on "won't start."
Smither
Smither
Loc: Central Illinois
Reg: 12-26-02
08-25-11 09:23 AM - Post#2130084
I 2nd the ignition module. Had almost same scenario on my '94 C1500. Was a bad module.
'04 Crew Cab
'95 C1500 Suburban
'95 GMC K1500
OL55
OL55
Reg: 01-01-08
08-25-11 06:21 PM - Post#2130271
    In response to Smither
I had to do the module, then the pick up coil on my '89 van. Doesn't hurt to have an extra module if that is the case.
Larry
Froadinman
Reg: 08-24-11
08-25-11 09:41 PM - Post#2130349
Thank you, both of you. Changed out the ignition module and it turned right over. I appreciate it!!! By the way I couldn't find the FAQ without actually looking it up in Google. I don't know if I'm blind or I just don't get the interface. This is a wonderful site!
08-26-11 03:11 AM - Post#2130370
Glad to hear you got it running and thanks for posting back with your results - it can help others reading in the future.
The FAQ is at the top of the 88-98 fullsize truck forum message list, titled "FAQ FREQUENTLY ASKED QUESTIONS / COMMON ISSUES"
Execution time: 0.196 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:47 AM
