Username Post: 1987 chevy truck stalls under load with low idle        (Topic#265964)
zippymailman
Reg: 07-10-11
07-10-11 07:10 PM - Post#2112746
Hello,
I have an 1987 Chevy truck TBI which has an annoying stall. It happens usually when I turn the wheel to the max and put a load on the engine (while maneuvering at idle speeds), or when coming to a sudden stop. It seems after the engine Idles down (after start up) it wants to idle a little on the ruff side and lower than normal. almost like the timing bypass is unplugged, low idle kind of ruff. (but its not)It does have new tune up parts (plugs, cap, rotor, fuel filter) I did time it to 0 degrees like the information said ( with the wire disconnected, sticker on the header panel). no change. I did put a new control module in and the crazy thing is after the truck would warm up it would die. If I disconnected the timing bypass wire it would stay running (a little ruff, but running) so I reinstalled the old one and it would stay running but same result. I did try more than one control module and I even had one of the new ones tested. (it tested good). I also tried a temp sensor with no change. I did pull the codes before I started changing parts and I had a 42, that's why I went to the control module. Today when I was driving the ck eng light came on. I checked the codes and I had a 32 (EGR) I did ck the EGR for free movement, which was good. I know the code is related to the EGR control not the EGR valve itself, and I don't thing it is related to my stalling problem but wanted to mention it. Any help will be greatly appreciated
Senior Chevytalk Moderator
07-10-11 08:03 PM - Post#2112770
    In response to zippymailman
Welcome to the site. Bookmark this page: http://www.cfm-tech.com/GM_tbi_tuning_tips.htm
How many miles does the TBI have on it? Engine codes for TBI FI are sometimes hard to pinpoint to something specific. You can add a few degrees of timing from 0. Have you checked fuel pressure? Compression on each cylinder? Remove and clean the air idle valve. Use a good TBI cleaner. Run a can of Seafoam through the tank. How old is the fuel filter? Is the EGR hose in good shape? Does the EGR valve stick? Clean it and air blow it. How good are the grounds? Check the battery to frame, engine to frame, and other grounds.
Vaughn
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
07-11-11 10:08 AM - Post#2112966
A low rough idle is a CLASSIC sign of a stuck-open EGR valve.
The fact that you might be able to get the pintle to move does NOT mean that the EGR valve is OK.
EGR is shut off when the engine is cold - and is activated when the motor is warm via the coolant temperature switch (CTS). EGR valve should ONLY OPEN at constant mid RPM with the engine under load (like when traveling down the road in 4th at 2000 rpm).
If there is a problem with the control or with the vacuum hose routing, the EGR can be activated at idle - which should never happen, because it CAUSES the rough idle and stalling.
You can disconnect the EGR valve as a test condition, if the engine does not idle rough or die WHEN WARM with the EGR valve disconnected, your control unit or the vacuum hoses going to the EGR valve are at fault.
If your truck still idles rough and dies when warm with the EGR control disconnected, you need to replace the EGR valve.
While the timing specifications for your truck indicate that it should be set for 0 degrees with the timing reference signal disconnected, your motor will run MUCH BETTER with 4 degrees or 8 degrees BTDC with the timing reference unplugged, and it will get better gas mileage.
zippymailman
Reg: 07-10-11
07-11-11 07:37 PM - Post#2113155
    In response to Vaughn
Ok, I will give that a try and see what I come up with on the EGR issue. What do you make of the Code 42 and the issue with the control module? I thought it was very strange that it would run better and than within a few minutes die, it did it with every new control module (2). and when I replace it with the old one it would stay running. The idle is low and more stumbley than rough.
zippymailman
Reg: 07-10-11
07-11-11 07:45 PM - Post#2113158
The truck only has 61,000 miles on it. It looks as if there is a good spray pattern when the truck is running, although I haven't checked the fuel pressure. Nor have I done a compression check. It seems to run fine anywhere above idle. The fuel filter is fairly new (3000-5000 miles), grounds all look good. I will check the (IAC valve, I think that's what it is called.) Any thoughts on the control module issue?
07-11-11 09:07 PM - Post#2113194
Code 42 may be bad due to wiring. Check the connections carefully. Basically open circuit or short or component failure. Have the first module tested at the parts store. Check if the distributor is receiving full voltage. Check the alternator and battery connections. Check for full power.
Vaughn
Vaughn
Reg: 08-08-04
07-12-11 05:21 AM - Post#2113253
You should deal with the trouble codes one at a time - because often the first trouble code is the problem, and second/third/etc are codes that are thrown because of the first code.
EGR does affect timing. Recirculating exhaust gases through the intake causes the combustion gases to be not-as-hot inside the cylinder (it also cools the block temperature) - so the TBI will advance timing on the motor when the EGR is active. This might be why you have a code 42 also, because that is the ignition control.
zippymailman
Reg: 07-10-11
07-13-11 07:17 AM - Post#2113637
OK, The code 42 is what I had to begin with, the code 32 came a couple of days later while driving above 45mph and the the ck eng light stayed on. when I started it the next time and it was off. I am assuming that the EGR control is not working properly because that is when the EGR valve should open (when I had the light come on, higher RPM's) Going to do some investigating today and hopefully find something.
07-13-11 07:20 AM - Post#2113638
Vaughn is spot-on about suspecting the EGR. Here's some troubleshooting info: http://www.chevytalk.org/fusionbb/showtopic.php?ti...
zippymailman
Reg: 07-10-11
07-13-11 07:27 PM - Post#2113885
    In response to someotherguy
OK, I ended up replacing the EGR valve, the idle did smooth out and pick up nicely. But, (there's always a but!) I took it on the expressway and the the Ck Eng light came on again. I am assuming that it is the EGR control module. And as I am pulling in the drive I was turning the wheel to the limit and I felt it stumble. So I let it idle as I was continuing down the drive and when I was at the point of almost stopping I was turning the wheel back and forth and it stalled. I started it up again and put it in gear (reverse) quickly and it stalled. How disappointing! any suggestions
Vaughn
Vaughn
Reg: 08-08-04
07-14-11 10:15 AM - Post#2114093
Get the code off of the computer first.
Did you advance the timing like I suggested above?
Bad Bowtie
Bad Bowtie
Loc: TX
Reg: 07-04-03
07-14-11 12:50 PM - Post#2114136
Do you even know if the exhaust passages are cleaned out?
You can install a new GM EGR valve, but it does no good if carbon has clogged up the holes in the intake manifold.
zippymailman
Reg: 07-10-11
07-14-11 06:41 PM - Post#2114256
I ended up changing the EGR selenoid and that fixed the CK eng light. still have the stalling when turning the wheel to the limits, also stumbling in the morning when I start it. acts like its wants to die and then rev's up to keep itself running. I was going to change the timimg but I was side tracked. somebody suggested that I check the Idle air control valve to see if it was gummed up. I pulled it off and it had a light film of what looked to be cigarett tar. I clean it up and re-installed it. The engine stalled as soon as I got it started. I purchased a new one re-installed it and the idle was very high. The instructions indicated that the truck should be drove at 40mph for about 4 miles for the computer to reset the IAC valve??? I did that and the Idle was still extremly high. re-installed the old one after I turned the plunger in a couple of turns and the truck stayed runinng. unplugged it as the truck was running and no change in the idle. I plugged the new one in as it was running and no movement on the plunger. Where does the plunger get its input from. I was told that the plunger would be moving rapidly back and forth. I really need some help with this. Thanks
zippymailman
Reg: 07-10-11
07-15-11 12:53 PM - Post#2114472
I put the old IAC valve in and it starts but with a low idle. the Idle will climb as the truck warms up???
Any suggestons
Vaughn
Vaughn
Reg: 08-08-04
07-15-11 06:30 PM - Post#2114553
The reason that I wanted you to adjust the timing is because it will have an affect on the idle speed. You should do this FIRST. Do not forget to disconnect the timing reference signal wire before changing the timing, otherwise the ECM will back out any timing changes you make.
The IAC control needs to be reset on whichever IAC you use. This is why your idle is so far off.
You shouldn't have messed with the set screw on the old unit. Small inputs on this screw can change the idle speed dramatically. Your old unit would have been correctly adjusted if you had only cleaned it and reinstalled it.
You can reset the valve using this procedure:
http://www.ehow.com/how_7959677_reset-bas eline-idl...
Be extremely careful to use a new gasket with whatever IAC you use, even tiny vacuum leaks will dramatically change rpm.
If you want an in-depth explanation of how the IAC works:
http://diy-efi.org/gmecm/papers/747iac.txt
zippymailman
Reg: 07-10-11
07-15-11 07:35 PM - Post#2114572
initially I pulled the IAC valve out cleaned it and re-installed it. I started the the truck and it would stall immediately. I pulled the IAC out again and noticed that if I turned the plunger it would lengthen or retract the shaft. I thought that as I was turning the entire valve out that the plunger may have been stuck and was turning out as well, so I turned it in a a few turns re-installed it and the idle was very high. I didnt mess the base idle on the TBI at all. I realized that I may have screwed this up and went to purchase a new one, installed it and the idle was extremely high. The instructions indicated to drive the vehicle for a while at 40mph and shut the engine off and re-start and the IAC would reset to correct position. Didn't happen. I then removed it turned the plunger out on the old IAC valve a little installed it and the truck runs but still has a high idle and it gets higher as the the truck runs more. I did plug the new one in to see if i could see any movement while the truck was running and I saw no movement. I believe that the IAC was working before because I would have a warm up idle and then it would decrease, or if I unplugged the temp sensor the idle would jump up. I don't think I can re-adjust the timing while at such a high idle. I did read in the information you supplied that the IAC is responsible for bumping up the idle when the engine requires it (A/C on, low voltage ect.) and then the computers takes over to keep this idle as a base until condition changes. the initial ondition I had was when turning the steering wheel to limits the idle would drop thus causing "low voltage" but no idle compensation and that's why I think it would stall. Is the ECM the only component that controls the IAC? Also the other link of information was to set the base idle on the TBI correct? (if so I didnt adjust it, it still has the cap on it) Is there any way to check to see if I have the required voltage changes or voltage at all in IAC pigtail?
Thanks for taking so much time, I really appreciate it.
Vaughn
Vaughn
Reg: 08-08-04
07-16-11 02:26 PM - Post#2114763
There are no timing advance mechanisms left in the distributor. They have been removed and are controlled by the ECM now. Disconnecting the timing reference signal unhooks the ECM from the distributor, so no advance is fed to the motor.
The ECM is the only thing controlling the IAC valve.
Turning the key off and on resets the IAC valve. It can also be reset by jumping the A and B terminals on the ALDL connector.
IF your IAC valve is installed correctly - and IF the IAC valve has been reset a few times - then you either need to adjust the pintle with the set screw OR you have a vacuum leak that is increasing the idle considerably (probably a brake booster hose/PCV hose/MAP sensor hose has become disconnected).
zippymailman
Reg: 07-10-11
07-17-11 07:52 AM - Post#2114938
Just a bit of info:
The idle increases as the truck warms up. I just dont think the IAC is getting any input I figured the IAC valve is controlled by the ECM but the ECM gets info from where so the IAC can make corrections? (MAP sensor?)I plan to replace the TBI gasket today and take a good look at the IAC valve when I have it off. I was not aware of a set screw to adjust the pintle. I will look for that as well. The high idle problem started when I removed and replaced the IAC valve so I am assuming the it is related to that but I will check all the vacuum sources too.
Thanks again for the continued effort and supply of information.
Vaughn
Vaughn
Reg: 08-08-04
07-17-11 04:23 PM - Post#2115061
The ECM gets the information to adjust the idle from:
The current RPM
The Coolant Temperature Switch (CTS) - whether in open/closed loop
The O2 sensor
Whether the AC compressor is on
The power steering pump
and the MAP sensor.
It reflects these values against a table of values in the EPROM, and if a number of values matches the table, it increases the RPM.
zippymailman
Reg: 07-10-11
07-19-11 02:53 PM - Post#2115812
well, I have no vacuum leaks and I reset the IAC valve, timed it at 4 degrees BTDC and it does idle better but still stalls. Mostly right when I start it now, after I drive it down the road it seems to "perk up" a bit. How does the ECM get input from the power steering pump? I didn't know it had any electrical hook up? can you shed some light on this. Thanks again
07-19-11 06:16 PM - Post#2115907
GM started using sensors on power steering to regulate idle/pressure on later models. I'm not sure when GM started to use the feature. I doubt your 87 has the input. If it does, it's the first time I have heard of it.
Vaughn
Vaughn
Reg: 08-08-04
07-22-11 11:12 AM - Post#2116818
How did you check for vacuum leaks?
What is your vacuum gauge reading?
Did you try advancing the motor more?
Timing makes more difference to a motor than you realize. GM publishes much tamer timing recommendations than it should, basically because of variations in production line tolerances (one motor might knock at 4 degrees, while another may not knock until 14 degrees). There are long an complicated reasons for this, but for now just advance the timing.
ECMs have the ability to read power steering pressure - if there is a demand for more pressure at idle (like when parallel parking) - the ECM reads the pressure drop and then kicks the motor idle higher in order to make sure the motor doesn't stall because of power steering pump demands. I don't know if you particular model has this sensor, it may not have been available yet.
Execution time: 0.2 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:33 AM
