Join the Community today
Username Post: 6 volt truck conversion        (Topic#265249)
lamothe1
lamothe1
Loc: cypress, ca us
Reg: 03-13-02
06-25-11 05:18 PM - Post#2107634
I just bought a ’46 chevy 1.5 ton truck with the stock 235 c.i. motor and everything is still 6 volts. I’d like to switch it to 12 volts. Will the gauges work on 12 volt and is there a chevy starter motor that’s 12 volt from a ’55 or newer that will bolt onto the 235 c.i engine?
06-25-11 08:18 PM - Post#2107675
    In response to lamothe1
No 12 volt starter will work. You can use your 6 volt starter, just don't hold it on to long. Will really spin the engine.
Here is the way to convert to 12 volt.
http://www.patricksantiquecars.com/articles.html
Execution time: 0.239 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:38 AM
