Username Post: ignition switch installation on 58 Impala        (Topic#265061)
prgm_mgr
Reg: 07-06-05
06-21-11 04:21 PM - Post#2106331
Hi again
Is it possible to install the ignition switch upside down on a 58 Impala?
I just installed a new switch, taking care to put it in the same way the original one was. I put the wires where they belonged (Red to batt, Pink to Acc and Tan to ignition).
When I looked at the diagram in both the Service Manual and the Accessory Manual, it seems the accessory is on the opposite side from where mine is.
The question is - what will happen if it is put in upside down but wired correctly?
Also, where should the little hole be for removing the lock cylinder - on top or on the bottom. This will help in deciding if its in correctly or not.
Thanks for your help
Mark
3483x2
3483x2
Loc: Middlesex, CT
Reg: 01-02-09
06-22-11 07:41 AM - Post#2106526
    In response to prgm_mgr
Mark - I hate to say it, but I think you'll need to do some re-wiring. Why?
Installing the switch itself upside down couldn't happen due to the (2) bezel mounting screws.
Second, I doubt the tumbler could be installed up side down fearing the cam slots just wouldn't line up. (I haven't tested this for sure, but suspect highly it wouldn't fit)
Sorry about that.
BTW - If memory serves the bottom hole frees up the tumbler.
Paul
http://www.cardomain.com/id/3483x2
Edited by 3483x2 on 06-22-11 07:44 AM. Reason for edit: No reason given.
speedygman
speedygman
Loc: Gorgeous Georgia
Reg: 06-27-08
06-22-11 09:32 AM - Post#2106563
The 58 Chevy ignitions switch P/N 1116544 does not
have a accesory position it. Lock,Off,On,Start. The 58 Chevy Taxi cab had a accesory position and the bezel shows Accesory,Off,On,Start. Taxi ignition switch P/N1116549 is the only 58 with accesory position. What switch do you have 544 or 549? Taxi bezel in picture
Attachment: 58_CHEVY_ACCESOARY_IGN_SW_WITH_ACCESOARY_POSITION.jpg (83.85 KB) 113 View(s)
Attachment: 58_CHEVY_ACCESOARY_IGN_SW_WITH_ACCESOARY_POSITION.jpg (83.85 KB) 98 View(s)
Speedygman (Grady)
http://www.picturetrail.com/sfx/album/view/204855 0...
Edited by speedygman on 06-22-11 09:38 AM. Reason for edit: No reason given.
prgm_mgr
Reg: 07-06-05
06-22-11 11:32 AM - Post#2106593
    In response to speedygman
HI again
My Bezel says from Left to right:
Lock/Off/On/Start.
Cylinder went in fine
As for the screws on the switch housing, the hooks on the housing are open facing right (so they'll snug up when the screw is tightened). They seem to be in the same position either way and there doesn't seem to be a slot to force one direction or the other when inserted.
Thanks again
Mark
WagonMan
WagonMan
Loc: Las Vegas, NV
Reg: 10-26-04
06-22-11 01:20 PM - Post#2106638
Both your pics are the same.
Charles
Charles
57 210 4dr. Wagon(bought '82)
-350/700r4 Mild Custom
56 BA 4dr. ht.(bought '98)
-265/TH350 Mostly Stock
29 Ford Sedan(bought '75)
-4.3L/TH350(in progress)
speedygman
speedygman
Reg: 06-27-08
06-22-11 02:29 PM - Post#2106661
    In response to WagonMan
Yes they are, I didn't have a picture of the Car bezel just the Taxi bezel. I have fat fingers when I was loading the pictures.
Speedygman (Grady)
Edited by speedygman on 06-22-11 02:29 PM. Reason for edit: No reason given.
prgm_mgr
Reg: 07-06-05
06-22-11 05:46 PM - Post#2106731
    In response to 3483x2
HI 348 3x2
I reread your post - the bezel is installed correctly, its the switch I'm wondering about.
Mark
Edited by prgm_mgr on 06-22-11 05:46 PM. Reason for edit: No reason given.
speedygman
speedygman
Reg: 06-27-08
05-15-12 06:59 PM - Post#2226344
Mark,
I have been looking a long time for the Taxi ignition switch P/N 1116549, I scored a NOS one on flea bay tonight. Now I can have a true accessory position on the wife's Brookwood 1958. I already have the restored Bezel on hand. For those that are nuts like me this is a great find for me. Couldn't have found it if not for the education that I have received from CHEVY TALK. Thanks to all.
Attachment: 1958_CHEVY_TAXI_IGNITION_SWITCH.jpg (187.48 KB) 110 View(s)
Speedygman (Grady)
Edited by speedygman on 05-15-12 07:16 PM. Reason for edit: No reason given.
Jerry Acheson
Jerry Acheson
Loc: Green Oaks, IL
Reg: 12-30-00
05-15-12 07:05 PM - Post#2226347
Jerry
Jens
58-60 Subject Matter Expert
Jens
Loc: Iowa.
Reg: 04-21-02
05-17-12 04:32 PM - Post#2226953
Nice find Grady. You've been looking for one of those for a long time.
speedygman
speedygman
Reg: 06-27-08
05-18-12 06:04 AM - Post#2227123
    In response to Jens
Jens,
I will never understand what makes me lock on to something that is so weird and almost unattainable. I sure am glad to get it and will soon get it installed and give a feed back on the accessory position switch.
Speedygman (Grady)
Jens
Jens
Loc: Iowa.
Reg: 04-21-02
05-18-12 01:43 PM - Post#2227278
So does that acc switch require a different wiring harness as well?
speedygman
speedygman
Reg: 06-27-08
05-18-12 08:04 PM - Post#2227396
    In response to Jens
No, it uses the same wire harness, electric plugs are the same. Bezel is different, it has Accessory position on the bezel. I will post some pictures soon of both switch's P/N 1115544 and P/N 1116549 showing the contacts and etc. along with the bezel of each kind. I am slow about things right now as I have had a little accident with my right leg.
Speedygman (Grady)
Edited by speedygman on 05-18-12 08:06 PM. Reason for edit: No reason given.
supremes
Reg: 01-05-13
01-05-13 05:41 PM - Post#2304335
i also have a question on a 58 impala, i was trying to take a ignition switch out at the junk yard, but there is no key, if there is no accessery on a 58 then what position does the key have to be on to release the tumbler? im going back monday with more tools.thanks
FiftiesMan
FiftiesMan
Loc: Washington, USA
Reg: 06-07-06
01-06-13 06:17 PM - Post#2304714
    In response to supremes
The tumbler has to be in the locked position with a key (this might work without a key if its in the locked position). There is a small hole at the lower left side of the key opening. A wire with the same diameter needs to be inserted into that hole. You should feel a spring like action when you slightly push on the wire. While pushing on the wire try to rotate the tumbler to the left (counter clockwise). The tumbler should release with a quarter turn. I don't know if the tumbler will release without a key though but it might be worth a try.
Impala58cvt
Loc: SoCal U.S.A.
Reg: 05-08-03
01-06-13 11:37 PM - Post#2304775
    In response to FiftiesMan
I use a paper clip.
supremes
Reg: 01-05-13
01-07-13 07:22 PM - Post#2305029
    In response to Impala58cvt
thanks for the information.
Execution time: 0.346 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:01 PM
