Username Post: Two headlamps on 1978 Corvette used for?        (Topic#264106)
jihujio
Reg: 05-03-11
06-04-11 01:32 AM - Post#2099134
On both front headlights on my 1978 Corvette, There are two actual lights. Only the 2 outside lights turn on when I activate the Head lights, what are the other ones for?
how do i turn on the high beams?
YeniPenny
YeniPenny
Loc: Biloxi, Ms
Reg: 11-26-01
06-04-11 07:22 AM - Post#2099211
    In response to jihujio
The two outside lights burn on low beam. All four lights burn on high beam.
To switch between high and low beams, pull back on the turn signal stalk.
ghustler
Loc: Southern Indiana
Reg: 09-06-04
11-24-11 06:16 PM - Post#2161622
oh my god, how old are you? Give up the vette before you can't figure out how to raise the hood when it catches on fire and go back to your bicycle!
TAT_2
"17th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
11-25-11 01:47 AM - Post#2161705
    In response to ghustler
09 PONTIAC- VIBE
08 PONTIAC- G6
96 FURD F-150 SUPER CAB XLT 4X4
NEXT ?
davidchristopher
davidchristopher
Loc: Saint George, Ontario, Ca...
Reg: 08-02-09
12-22-11 10:06 AM - Post#2171245
    In response to TAT_2
Clearly, the OP is a bot. 21 topics, no follow up posts.
either that, or he has a '90, an '85, an '81, a '79, and a '78 corvette, and a '93 and '98 camaro.
Also is shopping for ZR1s.
So, I call bs. Mods should ban user.
D
1951 Chevrolet Styleline Special. (350 4, Powerglide, '55 Driveshaft CE crossmember Heidts Mustang II front suspension, 3:10 Posi)
The '51 Chevy Blog
Execution time: 0.227 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:51 PM
