LMC Truck
Username Post: ECM-B Fuse blowing!!!!!!        (Topic#263112)
grunt99
Reg: 05-17-11
05-17-11 09:00 AM - Post#2091267
I have a problem with the ECM-B fuse blowing. I have a 2001 suburban 2500 2 wheel drive, 6.0L engine. the first time this happened i was towing an explorer it blew about 20 miles into the trip, swapped the fuse to 30a made it home no problems. i replaced the 30a fuse back to a 20a worked for about 3-4 weeks. the second time it blew wife was driving up our driveway that is inclined. it blew a 20 a fuse as soon as i put it in, put a 25a fuse in blew when i cranked the engine, put a 30a in it was fine. i have checked the wiring for obvious signs of a short. thinking that the fuel pump might be on it way out. Any help would be a great help
LMC Trucks
ratnfested
ratnfested
Loc: Rochester, NY. USA
Reg: 03-13-00
05-17-11 09:23 AM - Post#2091279
    In response to grunt99
I hear fuel pump or a bad connector on the tank can do that.
Philip Ferrera
1977 Chevelle
1977 Malibu Classic
1986 Grand Prix
1995 Tahoe
2003 Impala LS
2004 Ski Doo REV
Street Machines of Rochester NY
grunt99
Reg: 05-17-11
05-18-11 07:41 AM - Post#2091671
    In response to ratnfested
i was hoping this would be ez. but that is my luck will pull the tank this weekend
ratnfested
ratnfested
Reg: 03-13-00
05-20-11 11:03 AM - Post#2092726
try disconnecting the harness above it and see if its burnt. then yeah I guess I might pull the tank if all looks on the wiring.
Philip Ferrera
1977 Chevelle
1977 Malibu Classic
1986 Grand Prix
1995 Tahoe
2003 Impala LS
2004 Ski Doo REV
grunt99
Reg: 05-17-11
05-21-11 08:40 AM - Post#2093084
i'm still hoping it is the connector but cab got to it with out lowering the tank
grunt99
Reg: 05-17-11
05-21-11 02:37 PM - Post#2093199
my last post should have been, i can't reach the connector with the tank on but i think i'll dig around one more time
grunt99
Reg: 05-17-11
05-22-11 07:27 AM - Post#2093452
does this thing have two tanks???, i see one above the spare tire, where the filler line goes in, but there is a large hose going from the tank above the spare tire to another much larger tank, of some kind on the drivers side, now I'm really cofused, all looks stock PLS help!!!!
ratnfested
ratnfested
Reg: 03-13-00
05-23-11 10:33 AM - Post#2093932
tank should be on the drivers side. Not sure what is above the spare tire.
Philip Ferrera
1977 Chevelle
1977 Malibu Classic
1986 Grand Prix
1995 Tahoe
2003 Impala LS
2004 Ski Doo REV
shad2005
shad2005
Loc: Marion I.L.
Reg: 05-24-11
05-25-11 09:16 AM - Post#2094824
Easier to slide or remove truck bed than to drop tank.
Brian L.Shadowens
grunt99
Reg: 05-17-11
05-31-11 09:25 AM - Post#2097449
    In response to shad2005
sorry took so long to post back but with 4 kids not enough hours in the day. The suburban does have 2 tanks, the standard 29 or so gallon on on the drivers side and another tank above the spare tire. the fill line goes into the tank above the spare and gravity fills the larger tank. there are 2 fuel pumps also, primary running off the ECM fuse and secondary running off an ingition fuse. hopefully today i'll post the video following the fill line to both the tanks.
grunt99
Reg: 05-17-11
06-01-11 08:10 AM - Post#2097906
here is the you tube link to the video following the fuel lines from where you fill it up with gas thru both tanks
http://www.youtube.com/watch?v=bYxeJV0XtfE
grunt99
Reg: 05-17-11
06-06-11 05:31 AM - Post#2099892
well lowered the gas tank yesterday and the wiring looks brand new @ the fuel pump connector. so i'm ordering a new fuel pump
LMC Trucks
Execution time: 0.334 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:00 AM
