Username Post: Service Tire Monitor System Error        (Topic#261027)
DrPepper1010
DrPepper1010
Loc: Central VA
Reg: 07-17-07
04-11-11 08:05 AM - Post#2075073
I'm getting a Service Tire Monitor System error. I haven't serviced the brakes in months and don't know why it showed up. The truck has 63,000 miles.
Does anyone know what it means?
Does anyone know how to re-set it?
LMC Trucks
Bad Bowtie
Bad Bowtie
Loc: TX
Reg: 07-04-03
04-11-11 10:13 AM - Post#2075125
    In response to DrPepper1010
Read your owners manual.
It will tell you the "sequence of events" for resetting the Tire Pressure Monitoring system.
This has nothing to do with the brakes, unless you also rotated the tires w/o resetting the tire pressure system...
Vista Cruiser
Vista Cruiser
Loc: Erie Canal
Reg: 10-01-99
04-11-11 05:34 PM - Post#2075315
    In response to Bad Bowtie
You can mix the tires up and it won't care, but it will tell you the wrong tire is low.
An error is probably a bad sensor. You reset the system by pushing the second button down on the info button, when you get to it, push the "check" button, and/or as said, it's in your manual.
Go through the tires and see if one is'nt reading a pressure. If you reset, and it does'nt clear, ...sensor. I think they are about $40.
Do you have the "info system" If not, you'll need to go to the dealer or good tire store.
DrPepper1010
DrPepper1010
Loc: Central VA
Reg: 07-17-07
04-12-11 03:49 AM - Post#2075512
    In response to Vista Cruiser
Just as mysteriously as the error showed up, it's gone away.
Thanks for the feedback. I hope I don't have to do any of the things suggested.
Henrys57wagon
Canadian Regional Coordinator &"12th Year" Silver Supporting Member
Henrys57wagon
Loc: Carleton Place ON, Canada
Reg: 04-15-06
04-13-11 04:54 PM - Post#2076344
My 07 did the same towing my 5th wheel travel trailer in Feb, and now it is working as normal.
57 B/A wagon, 408"BB with 14' Bonair travel trailer,71 Nova 355"SB, 07 2500HD with 26 Prowler 5th wheel, 09 Impala LT, John Deere lawn tractor,
http://www.picturetrail.com/sfx/album/listing/use r...
DrPepper1010
DrPepper1010
Loc: Central VA
Reg: 07-17-07
04-16-11 04:06 PM - Post#2077589
    In response to Henrys57wagon
Well, the problem came back. This time the computer said there was no reading from the left rear. So I took the tire off. Looked for a sensor and found nothing. Then I took the brake drum off. Still no sensor.
Put things back together. Adjusted the air pressure in all tires and haven't had a problem since.
Is there really a sensor on the rear tires or does the computer just make something up to screw w/ our heads? If there is a sensor, where is it?
Vista Cruiser
Vista Cruiser
Loc: Erie Canal
Reg: 10-01-99
04-16-11 05:02 PM - Post#2077624
The sensor is inside the rim/tire at the valve stem. The tire has to be dis-mounted to get to it.
Matt
Matt
Loc: SAV
Reg: 09-26-01
04-16-11 06:39 PM - Post#2077676
What Kenney said.
Here's a generic pic of a tire/rim that has TPMS.
DrPepper1010
DrPepper1010
Loc: Central VA
Reg: 07-17-07
04-17-11 04:26 AM - Post#2077772
    In response to Matt
Sorry, I can't see the pic.
If the sensor is in the valve stem, where's the pickup from the computer? I don't see any wires inside the wheel well or on the axle.
Vista Cruiser
Vista Cruiser
Loc: Erie Canal
Reg: 10-01-99
04-17-11 05:12 AM - Post#2077788
Wireless remote.
LMC Trucks
Execution time: 0.169 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:41 AM
