Join the Community today
Username Post: Removing fleetmaster trim 1947        (Topic#258928)
Sc17842
Loc: York,pa
Reg: 02-23-11
03-09-11 06:19 AM - Post#2058381
Hello all, I am new to the site,and the chevy fleetmaster world. I just acquired a chevy fleetmaster from a friend of the family. I am the second owner, and the car is bone stock. The paint is horrible, but other then that it's just well loved. I am in the process of removing trim. I have removed the nuts on the trunk trim, but other parts appeared to ne attached to a bracket of some type which is screwed to the body. Can anyone help provide direction on how I go about removing the thin chrome trim from the doors b pillar rear doors and that huge u shaped piece?
David Hayward
Deceased RIP David
David Hayward
Loc: New Forest, UK
Reg: 04-10-99
03-09-11 09:23 AM - Post#2058496
    In response to Sc17842
Welcome to Chevytalk! I wonder if this online manual may assist you:
http://chevy.oldcarmanualproject.com/shop/1942_47/...
Sc17842
Loc: York,pa
Reg: 02-23-11
03-09-11 10:38 AM - Post#2058537
    In response to David Hayward
This is a great reference, but doesn't really deal specifically with the removal of trim. I'm sure there is a tool or technique out there
Sawtooth0645
Sawtooth0645
Loc: Colorado Front Range
Reg: 10-02-10
03-09-11 05:20 PM - Post#2058779
I have a '48 Fleetmaster station wagon, and removed old dented trim that ran the length of the doors and below them. I had a bolt or screw at one end. The rest of the trim was held on by clip-like attachments. Once the bolt was removed, I slid the trim off of them. Not sure if the ones you have are like that.
Sc17842
Loc: York,pa
Reg: 02-23-11
03-09-11 05:54 PM - Post#2058817
    In response to Sawtooth0645
So far I have been able to remove the end nuts, and they are loose, but i guess there are clips that are holding them in place. I am not able to slide the trim, and unsure how to "pop" it off the retainer clips without damage. The trim is in really good shape, so I am trying not to damage in any way
Sawtooth0645
Sawtooth0645
Reg: 10-02-10
03-11-11 01:11 AM - Post#2059563
Don't "pop" them off. Maybe they can be loosened behind with a lubricant. Check these links to see what the clips may look like. These may help you see how to shift them or remove the trim.
http://www.parts123.com/parts123/yb.dll?Parta~Part...
http://www.chevsofthe40s.com/dept/Car/cat/270C/Fen ...
Sawtooth0645
Sawtooth0645
Reg: 10-02-10
03-11-11 05:54 AM - Post#2059628
SC -
The first link I gave you didn't come up here on the page I found. You will have to go back a long ways to find it there. The 2nd link has the moulding clips at the bottom of the page. They can be turned a little in the slot, which could allow removal.
Sc17842
Loc: York,pa
Reg: 02-23-11
03-12-11 07:00 AM - Post#2060209
Hi all,
I spent a bit of time yesterday and got the trim around all the windows off with no damage. The tools that I used were a flat head screwdriver 1/4 width, thin tip, and a pick. I inserted the pick at the corner of the trim, and pushed in just enough to separate from the body so I could get the tip of the screwdriver in. I worked the pic in on the opposite side of the screwdriver, and with a twisting motion on the screwdriver, popped the trim off. I did wrap the screwdriver tip with a thing electrical tape layer to help avoid any damage. I worked my way around all six sidenwindows with no issues. I would be more then happy to provide any pictures if needed. My next project will be tackling the thick straight trim on the side of the vehicle. The body clips on my vehicle are rusted badly behind the trim, which makes it hard to remove :0(. I will keep you all posted.
Sawtooth0645
Sawtooth0645
Reg: 10-02-10
03-12-11 08:28 PM - Post#2060599
Plenty of replacement clips online. I'd replace rusty ones if they can't be cleaned up
historynw
historynw
Loc: Hudson Valley N.Y.
Reg: 03-04-07
03-14-11 10:30 PM - Post#2061801
If thats that long curve piece that sit at the top of the trunk under the window don't toss it. they are not reproduced. Mine was rusted we used rust converter and and were able to weld in a thin strip of metal in the channel to strengthen it. I then recoat the piece with a POR-15 product. We used newer clips to put the trim back on and it goes on hard. There is a post further down on finding clips they were good sources.
seeing the USA in my Chevrolet.....
Sc17842
Loc: York,pa
Reg: 02-23-11
03-22-11 04:19 PM - Post#2065635
    In response to historynw
All the chrome is off. I used the same technique as stated above. I broke some of the clips on the long u shaped piece, but the chrome is perfect. Thank you all!
Sawtooth0645
Sawtooth0645
Reg: 10-02-10
03-22-11 08:42 PM - Post#2065762
Good for you. Hope they all go back on smoothly.
Sc17842
Loc: York,pa
Reg: 02-23-11
03-27-11 04:00 PM - Post#2068178
Thank you sawtooth will let you know how I make out. FYI unsure how to respond back to you about the grille parts, but they are all from 47's please email me so I can send you photos
03-27-11 04:41 PM - Post#2068203
Click on his name and you can start a privite topic and email him direct.
Execution time: 1.902 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:10 AM
