Username Post: Look up your truck's options via VIN #        (Topic#258257)
Matt
Matt
Loc: SAV
Reg: 09-26-01
02-26-11 01:11 PM - Post#2052428
http://www.compnine.com/vid.php?vin=
Edited by Matt on 10-22-11 05:18 PM. Reason for edit: No reason given.
elcamino
elcamino
Reg: 03-30-00
05-06-11 06:52 AM - Post#2086750
    In response to Matt
CAUTION - -That info is not 100% fool proof.
It lists my CTS as a DTS, totally different model and platform. CTS is a rear drive and DTS is front drive and a much bigger car. So there must be some programing error. Its does not stop there, read on
It returns the wrong description for G80 on trucks and suv's It says its a limited slip differential BUT that is not correct. G80 has 2 meanings, one for cars and one for trucks/suv's which that lookup does not seem to differentiate.
G80 in a truck or suv is a Eaton Locking rear differential, it is not a Positraction Limited Slip as the option report says.
Many use the info as gospel and go adding limited slip additive to their G80 Locking differential and that can lead to the locker not engaging or worse.
From GM
Equipped With a Locking Rear Differential RPO G80
***Important: Installing any friction modifier causes the clutch pack in the locking differential to slip and miss engagement. A fluid flush can often remove debris that is a contributor to clutch chatter. Adding friction modifier additive can cause a loss of locking differential functionality***
2017 GMC Sierra Denali Ultimate 6.2L(420hp)/8-sp
2016 Polaris RZR 900 EPS
elcamino
elcamino
Reg: 03-30-00
10-22-11 04:19 PM - Post#2150010
    In response to elcamino
These types of announcements don't come easy, but effective immediately Comp Nine will be closing its doors permanently.
Thank you to everyone that helped keep the site going and for allowing Comp Nine to serve the community for so many years.
Please contact service@compnine.com if you have any immediate concerns.
Matt
Matt
Loc: SAV
Reg: 09-26-01
10-22-11 05:19 PM - Post#2150024
Darn! That was an excellent resource!
If anyone knows of another VIN decoder site, please do let me know!
Henrys57wagon
Canadian Regional Coordinator &"12th Year" Silver Supporting Member
Henrys57wagon
Loc: Carleton Place ON, Canada
Reg: 04-15-06
10-31-11 07:11 AM - Post#2152967
    In response to Matt
They are no longer operating:(
57 B/A wagon, 408"BB with 14' Bonair travel trailer,71 Nova 355"SB, 07 2500HD with 26 Prowler 5th wheel, 09 Impala LT, John Deere lawn tractor,
http://www.picturetrail.com/sfx/album/listing/use r...
10-31-11 07:19 AM - Post#2152973
    In response to Henrys57wagon
Decoding the VIN isn't that big of a deal; the information is out there. What Compnine was great for was returning to you all the RPO codes unique to your vehicle, and giving the description of each RPO. You can still do this...manually...if you have access to your RPO codes.
On the 88-98 fullsize trucks, the RPO codes are on a sticker inside the glovebox. I suspect they're in the same place or similar on the newer trucks. I strongly suggest you take a clear, close-up, digital picture of your sticker and save a copy of it on your computer for future reference, in case anything ever happens to it. On the 88-94 trucks many of them are illegible now because GM in their wisdom placed it on the floor of the glovebox; stuff rubbing on them over the years have scratched them badly.
Here is a link straight to GM with a lot of VIN decoding cards, particularly for the later model vehicles: http://service.gm.com/dealerworld/vincards/
For the 88-98 trucks I have compiled data from many different sources and made my own VIN decoding card: http://www.someotherplace.com/info/GMT400VINCARD.J...
This can tell you what country your truck was made in, manufacturing division, GVWR (gross vehicle weight rating), chassis type (2wd, 4wd), series (1/2 ton, 3/4 ton, etc.), body type, engine type, model year, and manufacturing plant.
You can decode your RPO list from your glovebox sticker by using one of the many collections of RPO codes found around the internet. These sites come and go over the years; I found one really complete reference and have hosted it on my site in hopes I can provide it in the event its other sources go away: http://www.someotherplace.com/info/RPO.pdf
Keep in mind that sometimes a particular RPO code can be recycled so it may not always mean the same thing from year to year, or model to model. For example, MT8 in this list indicates an 18 speed manual transmission (heavy truck) but on early 90's light trucks is actually the NV4500 5 speed. So, no list is 100% correct but this one will get you most of the way.
elcamino
elcamino
Reg: 03-30-00
10-31-11 12:53 PM - Post#2153094
    In response to someotherguy
As stated, an option code can mean several things. You have to use it in context with the vehicle
For Instance. here is all the iterations for G80
G80 Differential, heavy-duty locking rear
G80 Differential, automatic locking rear
G80 Differential, heavy-duty automatic locking rear
G80 Differential, limited slip rear
G80 Differential, locking, heavy-duty, rear
G80 Differential, Zexel-torsen, limited-slip, rear
G80 Rear Axle: Positraction
G80 Locking, Rear Axle
G80 Axle Positraction Limited Slip
G80 Differential, locking, rear
G80 AXLE POSITRACTION LIMITED SLIP
10-31-11 12:55 PM - Post#2153097
I knew G80 was used for the Eaton Gov-Loc in the full size trucks, and both positraction and limited slip in some car applications, but I didn't know it had THAT many meanings.
elcamino
elcamino
Reg: 03-30-00
11-02-11 04:03 PM - Post#2153886
And there are other codes related to rear axles
G85 Differential, limited slip
G86 Differential, limited slip
G86 Differential, limited slip, heavy-duty, rear
G85 AXLE REAR LIMITED SLIP, VAR 1
G86 AXLE LIMITED SLIP
G85 has been seen on option labels in HHR's.
G86 in rear steer trucks
Execution time: 0.212 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:17 AM
