 Page 2 of 2 <12
Username Post: 5.7 TBI injector problems        (Topic#257512)
txturbo
Loc: Rosenberg,TX USA
Reg: 07-27-01
10-28-14 05:30 PM - Post#2494342
    In response to navygunner08
I had this same problem about a month ago on a van that had been parked since 2008. Naturally the fuel pump was bad.....replaced that and had good fuel pressure. Still wouldn't start. Sprayed gas in the snorkel of the air cleaner and it would start and die. Kept putting off pulling the air cleaner because its a van and I wasn't looking forward to pulling the engine cover. It also has a propane conversion. Finally broke down and pulled it all off. Injectors weren't firing. Got frustrated and tapped one of them with a wrench. It started firing. Motor started and ran on one injector. Tapped on the other one and it started firing. Been starting and running great since.
Dan
1969 Camaro SS 396/T400
1966 Impala 283/PG/AC
1966 Impala SS 427/4 Speed
1948 Panel 1 Ton
1963 Cadillac
1940 Ford P/U
1954 Chevy 3100
1955.2 Chevy 3100
1956 Cadillac CDV PINK
1930 Model A hot rod
Dale_Holley
Loc: Dallas, TX.
Reg: 11-10-03
10-30-14 08:58 PM - Post#2494905
    In response to txturbo
You can also try to rent or borrow a noid test light to plug into the TBI connectors and have a helper crank the motor while you watch the noid light to see if it is blinking while cranking. If it does not blink on and off then you know that you have a eletronic / wiring / ECU / Ignition related problem.
Lowriderloner2000
Reg: 12-27-16
12-27-16 07:46 PM - Post#2668150
    In response to Dale_Holley
12-27-16 06:38 PM - Post#341758
I have 95 Chevy s10 pickup it was running and when I went to start it it would run the fuel pump would not kick in so I ended up replacing it still nothen IV replaced the oil pressure switch the fuel pump relay under hood the ones in glove box is good but last my ecm b fuse was blew so I replaced it but as soon as u turn key on pow blown I couldn't find no chafed wires and I also cleaned all grounds that I could find what else could it be o and I am getten spark from spark plugs
 Page 2 of 2 <12
Execution time: 0.563 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:56 PM
