Username Post: How to tell if Harmonic Balancer Bad?        (Topic#257402)
bfr57
Loc: Tucson, AZ
Reg: 04-30-04
02-11-11 09:06 AM - Post#2045160
How can you tell if factory harmonic balancers are good or not? If they look visibly OK, run 'em? I'm just starting a refresh of my .030 SBC and got looking at the balancer last night and wondered about that. I didn't feel any vibes before removing, but it is an early 70's motor. How long can you run them?
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
02-11-11 09:16 AM - Post#2045169
    In response to bfr57
the elastomer ring bonding the inner and outer hobs tends to start swelling, cracking and have chunks start to fall out in most cases when they go bad, if the inner and outer ring are not parralel, i.e. the outer ring has moved its an indicator of its failure
scottsdale84
Loc: Oakland IA
Reg: 11-19-08
02-11-11 12:52 PM - Post#2045266
    In response to grumpyvette
for what a new replacement costs i wouldnt even bother reusing it. i would get a new one just for the peace of mind
Mister Blue
Loc: Duluth, MN
Reg: 12-04-07
02-11-11 04:00 PM - Post#2045347
    In response to scottsdale84
The keyway lines up with the TDC mark on the outer ring. Had a new Professional Products that slipped. Could see that the keyway and TDC did not line up.
D.Mac
Loc: Ontario Canada
Reg: 03-22-03
02-11-11 04:53 PM - Post#2045383
    In response to Mister Blue
The keyway is 10 deg before TDC on 1969 and later engines. 2 degrees on pre '69.
Dave MacDonald
Ontario, Canada
'66 Impala LT1/C950-,EFI,700R4,(sold 07/2011)
'12 Sonic LTZ, Turbo, M6
'07 Pontiac Solstice GXP
'06 Caddy CTS-V
Brian HHP
None
Reg: 12-24-10
02-11-11 05:01 PM - Post#2045387
I agree with this. Dampeners are cheap compared to having one fail and the damage I have seen them do when they do fail. Not too mention, replacing the old factory dampener with a better piece from say ATI, will help your new engine last longer, rev smoother and help prevent any future issues.
My buddies 96' Cobra had it's dampener fail at 7,200rpms and it broke the front off the crank and destroyed everything around it.
Project Sublime - 00' Dodge Dakota, 355/4L60E swap
Co-owner and Engine builder for HHP
Execution time: 0.295 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:49 AM
