Username Post: 3chd tranny part no?        (Topic#256370)
88silverado
Reg: 01-22-03
01-23-11 11:22 AM - Post#2035994
I have bought what I believe is the correct trans I need for my 2001 sierra 1500 2wd. The new trans has the code 3chd. Correct me if I'm wrong, but from my research this came from a 2003 2wd c1500 or g2500. This should be the same as my 2001 (tag is missing but from my understanding should be 1chd). Does anyone have any input or advice on this? Or have I correctly gathered the parts I need?
Welcome to Oil Country
88silverado
-56 chev longbox
-68 beaumont 4 door
-76 olds 98
-81 chev custom deluxe
-88 silverado (starting resto)
-92 gmc ext cab
-96 gmc ext cab (wrote off)
redvett01
Loc: Wickenburg, AZ
Reg: 10-23-03
01-23-11 11:59 AM - Post#2036010
    In response to 88silverado
A G2500 transmission is a 4L80E and your truck needs a 4L60E for a C1500.
K1500 04 Silverado EXT
88silverado
Reg: 01-22-03
01-23-11 12:06 PM - Post#2036011
    In response to redvett01
apparently from the information I found, the g2500 with a 5.3 has the same 4l60e as the half ton, it's the 6.0l that has a 4l80e
88silverado
-56 chev longbox
-68 beaumont 4 door
-76 olds 98
-92 gmc ext cab
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
01-23-11 12:44 PM - Post#2036030
http://www.ls1tech.com/forums/automatic-tran smissi...
82 Monte Carlo SC, 355 w/Vortec heads, roller rockers, 670 Street Avenger, TRUE DUALS.
2009 Sub.5.3L LTZ 30 Gallons of gas @ $2.49/gal. bla bla bla.
88silverado
Reg: 01-22-03
01-24-11 05:54 AM - Post#2036403
    In response to black95jimmy
So the information I found is correct, this is out of a 2003 g2500 van with a 5.3l. Can anyone confirm if this trans will fit in my 2001 gmc reg cab shortbox 2wd?
88silverado
-56 chev longbox
-68 beaumont 4 door
-76 olds 98
-92 gmc ext cab
88silverado
Reg: 01-22-03
01-24-11 04:16 PM - Post#2036654
Thanks for the help everyone, the local gm dealership FINALLY confirmed that this transmission is a direct swap into my 01. I believe he said 99-04 is all the same. I thought it would be more like the earlier 4l60e that changed something every couple of years!
88silverado
-56 chev longbox
-68 beaumont 4 door
-76 olds 98
-92 gmc ext cab
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
01-25-11 04:33 AM - Post#2036909
Execution time: 0.276 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:32 AM
