Nick_nl
Loc: Netherlands
Reg: 12-29-07
01-18-11 10:50 AM - Post#2033713
Hi Guys.
A question about parts for this carb.
My car has a 4bbl WCFB, this has been rebuild. But the throttle shafts are worn quite a bit.
I found a guy who has Studebaker WCFB part for sale. He has a pair of throttle shafts. Are these the same as for Chevrolet?
He gave me the part numbers for carter Studebaker 3-1054S and 3-1110S.
This
Forum is Sponsored by
carbking
Loc: Missouri
Reg: 06-14-03
01-18-11 04:20 PM - Post#2033835
In response to Nick_nl
No.
Jon.
Good carburetion is fuelish hot air!
The most expensive carburetor you will ever buy.....is the incorrect one you attempt to modify!
If you truly believe "one size fits all", trying walking a mile in your spouse's shoes! |
57belairman
Loc: Missouri City Texas USA
Reg: 03-16-02
01-18-11 06:54 PM - Post#2033915
In response to carbking
Doesn't get any better than that Nick.
Life is short, Eat dessert first, I always do!!
Picturetrail
57 2dr ht red
57 Convertible
57 Nomad
57 2dr Sedan
57 3100 Pickup
55 2dr Sedan
56 Suburban |
Nick_nl
Loc: Netherlands
Reg: 12-29-07
01-19-11 09:16 AM - Post#2034159
In response to 57belairman
That's a clear answer. Thanks.
carbking
Loc: Missouri
Reg: 06-14-03
01-20-11 06:23 AM - Post#2034545
Nick - measure the clearance from the shafts to the throttle body (dial indicators are relatively inexpensive).
The original Carter specification was 0.004~0.006 inch.
Some wear is normal. If the clearance does not exceed 0.009 you should be able to adjust the carburetor such that it works very well.
As far as interchangability on throttle shafts:
The throttle arms used by Studebaker are totally different than those used by Chevrolet.
IF YOU ARE A GLUTTON FOR PUNISHMENT:
Remove the throttle shafts from your carburetor (remember to grind off the back of the screws before you attempt to remove them which will necessitate new screws). Ignore the arms, and compare the shafts alone to the Studebaker shafts. It MIGHT be possible to grind off the end of the shaft affixing the throttle arm, chuck the are shaft up in your lathe, drill and tap the end of the shaft, machine a special retaining screw, place the Chevrolet arm on the Studebaker shaft and affix with the retaining screw.
But if you have access to this tooling, simply machine a new throttle shaft.
Jon.
Nick_nl
Loc: Netherlands
Reg: 12-29-07
01-20-11 12:30 PM - Post#2034672
Thanks for the measurements. No access to a lath. But a friend of mine does have a lath. Making a new axle might be easier than the procedure you just described
First I'll get a dial indicator to see how bad it is. Might just be within spec.
This
