Username Post: Help: 2002 4.3l High Idle and p0300        (Topic#255164)
jpsage
Reg: 12-06-10
01-01-11 01:49 PM - Post#2025410
OK, I am tired of learning; it is now time for me to get this thing running well enough to get it 1250 miles home to WA.
2002 Sonoma XR2 4.3l 125K miles.
It started with a P0305 and miss so bad that you thought you were driving on over railroad tracks. I brought it back to the house and took out the plugs (worn but without symptoms), did a compression check (130-140) and decided to replace the spider in a sunny Southern CA driveway. Sure enough the old injectors were really ugly and the there were signs of the manifold leaking. Also put in new plugs, wires, rotor, cap.
I put it all back together and the idle was 1800 and it immediately threw a p0300. Worse was that the idle would continue to climb until I shut the car off. Off to Harbor Freight for a vacuum gauge that read low normal. I started reading about how to use my scangauge's Xgauge. I was able determine that the computer was commanding the IAC to 0 and telling the car to go to 600 rpm and that the system is in open loop.
I covered the idle air inlet and started the car and the idle went to approx normal. I immediately shut the car off and ran to Autozone to get a new IAC thinking that I had it solved. Well better about 1100 rpm but not right yet. I took the upper manifold off and see oil spatter around the No. 4 injector.
Oh, one more thing. I know how most of the components work but I lack information on how the whole thing works together. Like what happens when the key is turned on, on first crank, how it determines when to go into closed loop etc. I have been searching the net but haven't found anything comprehensive. Can you guyes point me to a link or recommend a book that covers that material? I want to put a LS in my 72 c20 but after this experience, I am not going there until I know more about how the whole system works.
Please don't make me take it the dealer with my tail between my legs
Sorry for the long post but thanks so much for any help,
john.
Chevytech
Chevytech
Reg: 04-25-04
01-01-11 04:34 PM - Post#2025440
    In response to jpsage
The system monitors the O2 sensor voltage as one of the main criteria to go into closed loop operation. There is other criteria, but the o2 sensor is the main criteria.
The IAC count should never reach zero. The engine has a vacuum leak. A vacuum leak will cause a high idle, and a low IAC count.
When you replace, remove and cleaned an IAC, or unplugged the IAC with the key on, the ECM may need to relearn the IAC position. This will not happen without driving the truck and meeting specific conditions or taking other steps the cause it to relearn the idle.
The EGR could be stuck open a little bit.
jpsage
Reg: 12-06-10
01-02-11 03:35 PM - Post#2025897
    In response to Chevytech
Well the tutorial continues
After hours of searching under the hood and on the net, "I hab no bananas" or EGR valve either I guess some the the 'W' trucks did not have an EGR just like the new V10 in my motorhome.
Seriously tho, this truck came from my daughter who was starting to have a lot of trouble with it and one of the things that she said to me just rang a bell in the back of my mind. She said that she had to replace her gas cap several times in the past year because it wouldn't hold the seal. At the time I dismissed it as being a person who knows little about cars replacing something unrelated to anything. I now think it might be the core problem.
I will now look on-line for troubleshooting techniques for the evap system. I will post what I find.
Thanks,
john.
Senior Chevytalk Moderator
01-02-11 07:09 PM - Post#2025997
Welcome to the site.
Causes: A code P0300 may mean that one or more of the following has happened:
Faulty spark plugs or wires
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector(s)
Burned exhaust valve
Faulty catalytic converter(s)
Stuck/blocked EGR valve / passages
Faulty camshaft position sensor
Defective computer
Taken from http://www.obd-codes.com/p0300
You can find wiring diagrams and factory info at www.autozone.com. They have a good do it yourself maintenance section.
jpsage
Reg: 12-06-10
01-08-11 02:42 PM - Post#2028913
Success Some idiot--oh, that would be me--screwed up on the intake manifold installation. Re-tear down and new gasket and all seems good with the world. I will take it out on the learn cycle now and see how it runs. I will post a complete review later along with a couple of lessons learned.
Thanks guys, it is wonderful to have someone to talk to about this stuff.
john.
Chevytech
Chevytech
Reg: 04-25-04
01-08-11 05:13 PM - Post#2028995
Glad to hear things worked out ok, and thanks for sharing what the problem was.
Execution time: 2.455 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:31 PM
