Username Post: Oil Filter PF46 vs PF61        (Topic#254377)
schunt
Loc: South Lyon, MI
Reg: 11-06-01
12-15-10 12:21 PM - Post#2018427
I've noticed over the past 10 years there have been a few different oil filter PF#'s for the 2000-2002 Silverado with the 5.3L.
The most resent one is the PF46 which is shorter than another variation that I remember using a few years back. At the Autopart store yesterday I opened a taller PF61 filter. It seems to have the same diameter and thread pattern, The dimensions of the two look the same with the exception of the PF61 being taller. Even the metal part on the inside with the threaded hole and the 6 through holes had the same stamp of "G" on it.
I am going to give it a try aas it has more oil capacity and will be easier to get on and off with my filter wrench with the additional 1 inch of depth.
Has anybody used this filter on their 5.3L before?
Does anyone know what the difference is between the two?
1981 Silverado 2wd
2000 Silverado 4x4
1970 Chevelle
CaptainK
CaptainK
Loc: Maryland
Reg: 02-25-02
12-16-10 05:25 AM - Post#2018727
    In response to schunt
There are some other threads in here from a year or so ago and back that discuss this as well as other filter comparisons (too many to link too). The short of it is that the PF61 will work just fine
'99 Silverado (NBS)
elcamino
elcamino
Reg: 03-30-00
12-16-10 06:22 AM - Post#2018742
    In response to CaptainK
AC Delco does not make the spec's known but I looked the Wix filters for comparisons.
Basically the 46 is used for V8 applications while the 61 is for 6-cylinder applications. Aside from the size difference, one has a higher burst strength than the other.
More Information
This is what shows up searching AC Delco parts
FILTER ASM,OIL PF61 (CLASSIC)
Part Number: PF61
Product Information
Total number of applications: 643
FILTER ASM,OIL PF61E
Part Number: PF61E
FILTER ASM,OIL PF46E
Part Number: PF46E
Total number of applications: 443
FILTER ASM,OIL PF46 (CLASSIC)
Part Number: PF46
PF46 cross reference
Part Number: 51042
UPC Number: 765809510425
Principal Application: Various GM Cars & Trucks (75-76) (96-10)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 13/16-16
By-Pass Valve Setting-PSI: None
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 320
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
PF61 cross reference
Part Number: 51522
UPC Number: 765809515222
Principal Application: AMC (82-86), GM, Saturn (93-10), Jeep (81-86), Isuzu (03-09), Saab (06-09)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.526
Burst Pressure-PSI: 290
Gasket Diameters
2017 GMC Sierra Denali Ultimate 6.2L(420hp)/8-sp
2016 Polaris RZR 900 EPS
elcamino
elcamino
Reg: 03-30-00
12-16-10 11:16 AM - Post#2018845
    In response to elcamino
Here is more info on AC Delco filters
ACDelco Launches Redesigned OE Oil Filter
By Blog Post on November 4, 2009 1:01 AM | No Comments
ACDelco has announced a redesigned Original Equipment (OE) oil filter that offers ACDelco's exclusive Duraguard® media in a smaller package.
The new OE filter applications PF46E, PF47E, PF52E and PF61E will be installed in applicable new GM models.
The new oil filter features:
• Increased efficiency and higher burst and collapse strength (Fig. 5, A)
• A new Nylon core that provides better flow characteristics and improved collapse strength
(Fig. 5, B)
• A full cover baseplate that allows easy installation in blind applications (Fig. 5, C)
• Duraguard media, ACDelco's trademarked synthetic cellulose-blended media that
efficiently filters particles as small as 10 microns -- 1/3 the width of a human hair -- to
ensure a clean supply of oil to engine components (Fig. 5, D)
• A combination relief and anti-drainback valve that prevents dry starts and assures oil flow
(where applicable) (Fig. 5, E)
In addition to the new OE design oil filter applications, the original filters (PF46, PF47, PF52 and PF61) continue to be available in a classic design.
ACDelco Part Number with Corresponding GM Part Number
Classic Design
PF46; 19256041
PF47; 19256042
PF52; 19256043
PF61; 19256044
New OE Design
PF46E; 19210283
PF47E; 19210284
PF52E; 19210285
PF61E; 19210286
For more information about the new ACDelco oil filters, refer to ACDelco bulletin #09D-142.
Execution time: 0.27 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:26 PM
