Username Post: 153 tooth flywheel vs 168        (Topic#252712)
OldDad
OldDad
Loc: The Great NorthWest
Reg: 06-06-04
11-14-10 09:38 PM - Post#2004405
Any advantages to using one or the other? I've got a mild 327 tripower with a wide ratio Muncie and a 3:08 axle. All opinions welcome.
The S.O.B. from the factory...
71 1/2 ton, 64 Chevelle SS, 57 2dr Hardtop, 57 2dr Sedan, 57 Corvette, 52 2dr Hardtop, 52 2dr Sedan, and now a 49 Plymouth Coupe, 1930 Model "A", 1934 Ford Truck, all Chevy powered of course.
SAM_57
SAM_57
Loc: SE VA USA
Reg: 06-20-01
11-15-10 04:47 AM - Post#2004473
    In response to OldDad
You first need to figure out which bellhousing you will be using. A factory style, with bellhousing mounted starter, will require the larger diameter flywheel. If using the block mounted starter, then the smaller flywheel will need to be used.
The clutch diameter is also tied to the flywheel diameter.
S.Pollard 57 Belair sport coupe 69 C/10 stepside (wife's) 84 Monte Carlo SS
11-15-10 05:54 AM - Post#2004490
    In response to SAM_57
Block mounted starters can be used with the 168 tooth flywheel. They are the ones with a diagonal mounting pattern.
The 153 tooth starter has a straight across mounting pattern.
You can use either one, the starter/bellhousing just has to match. Most heavy duty setups use the big flywheel.
11-15-10 06:36 AM - Post#2004502
With the 153 teeth flywheel, you can ONLY USE a 10 1/2in clutch.
ALL V8 flywheels up through 62 were ONLY the 168 teeth version, BUT, they had a bolt pattern for the smaller 10 1/2in clutch. A later model 168 teeth flywheel will have the bolt pattern for the larger, 11in clutch, which I would STRONGLY recommend if you are going to use a 3.08 rear gear. The reason is because slightly more torque will be required to get the 3.08 turning, thus, just a little additional feathering of the clutch will be necessary from a dead stop and the larger 11in clutch will simply be a better choice because of the greater contact surface of an 11in clutch vs a 10 1/2in clutch.
Now, for me personally, I run a 168 teeth flywheel/11in clutch in EVERYTHING I own.
My philosophy regarding a clutch is the same as my philosophy regarding cubic inches. Too much is just right!
OldDad
OldDad
Reg: 06-06-04
11-15-10 11:06 AM - Post#2004626
Thanks to all for the answers. Great information.
Highlander1
Highlander1
Loc: SE North Carolina
Reg: 08-19-04
11-17-10 07:32 PM - Post#2005797
  • DZAUTO Said:
ALL V8 flywheels up through 62 were ONLY the 168 teeth version, Now, for me personally, I run a 168 teeth flywheel/11in clutch in EVERYTHING I own.
Can the 168 teeth flywheel/11in clutch combination be used in the stock 55-57 pass car bellhousing? Thanks, Don
11-17-10 08:44 PM - Post#2005836
    In response to Highlander1
Yes it sure can. In fact it should be the #1 choice. #1a would be a similar setup with a 10.4" clutch.
awsum55
awsum55
Loc: O.P. Kansas
Reg: 09-27-01
11-17-10 09:03 PM - Post#2005842
I'm pretty sure that is the set up I had. I changed over to a scattershield because I planned on taking it to the track.
The only thing I think I had to do was cut away part of the bellhousing so the starter would fit/work right.
Five things that you cannot recover in life:
* The Stone after it's thrown
* The Word after it's said
* An Occasion after it's missed
* The Time after it's gone
* A person after they die
11-18-10 10:23 PM - Post#2006280
Ummmmmmmmmmm, sorry, I thought I made that clear. Yes, that's what I have in my cars that have the 55-62 style open bottom bell housings (BOTH iron and alum versions).
Up through 1985, ANY 168 teeth flywheel with the bolt pattern for an 11in clutch will retrofit all the way back to a 1955 V8.
Now, just as sure as God make little green apples, someone is going to jump in here with a comment regarding EXternal balanced flywheels such as those used on the SB400 and the 454BB. So, I better clarify that before someone gets all bent out of shape.
The NEUTRAL balance 168 teeth and the EXternal balance 168 teeth flywheels are 100% the same and are TOTALLY interchangeable with each other and will bolt onto the back of ANY 55-85 V8 engine and ANY 63-later inline Chevy 6cyl. The ONLY difference between neutral and EXternal balance flywheels is that added weight on the EXternal balance flywheels which is needed for a SB400 and a 454 (YES, there is a difference in the added weight between a SB400 and a 454 flywheel). See picture below.
Furthermore, the ONLY size flywheel used on the SB400 and 454 was the larger 168 teeth version (because of that needed extra weight on one side for balance purposes). They never got the smaller 153 teeth flywheel.
As an example of where this is important, is let's say you have a 55 Chevy with a 4sp and you want to drop in a SB400 or a 454. You can literally unbolt the stock 265 from the 55 (or later) bell housing, and drop in the SB400 or 454, with the large 168 teeth flywheel/11in clutch, bolt it up to the 55 bell housing and drive it away. Ya, ya, ya, ya, ya I know, you gotta do a little massaging to a 55-57 Chevy to drop in a BB if it is to fit in there with the bell housing/tranny in the stock position.
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
11-19-10 05:44 AM - Post#2006355
When I bought my Muncie, the seller gave me a small one-piece aluminum bellhousing (1964 date code) and a GM 153-tooth cast iron flywheel. I spent $45 to have the flywheel ground and a whopping $90-something on a Pioneer stock replacement clutch kit. Behind a mild 350, the setup worked like a charm for 3 years. In fact, when I pulled the engine, the clutch disc looked almost new.
When I dropped in my new, higher-revving 327, I didn't have the money for the larger safety bellhousing I wanted, so I bought an inexpensive 153-tooth steel flywheel and a 10.5" Zoom street/strip clutch. After 3 years of moderately-aggressive street driving the clutch still works great. More than likely, the old stock clutch would still be working well, too.
Some day I may go to a Lakewood bellhousing. When/if I do, I might make the jump to a larger flywheel and clutch, but I expect the current setup will serve me well for years.
If you're starting from scratch, go with the 168/11 setup. If you already have some 153/10.5 parts, they will work well with your mild 327.
Edited by MikeB on 11-19-10 05:46 AM. Reason for edit: No reason given.
11-19-10 09:06 AM - Post#2006438
    In response to MikeB
YEP!
Highlander1
Highlander1
Reg: 08-19-04
11-19-10 11:10 PM - Post#2006744
Thanks Tom. Just wanted to be sure I understood correctly. Mike has raised a question regarding clutch safety. Since I plan/want to use the stock bell housing I also plan to use an SFI-1.1 certified flywheel and clutch. Is this combination considered an acceptable alternative to say, a Lakewood explosion proof bell housing? Also, it seems to me that many years ago there were external shields on the market. Lately have only seen them for autos. Regards, Don
11-20-10 07:06 AM - Post#2006823
If you want to be safe you use both.
tmsnyder
tmsnyder
Loc: Buffalo, NY
Reg: 06-13-06
12-05-11 07:34 AM - Post#2165229
Thanks for the good info Tom. I wish I'd looked up this thread before ordering the wrong flywheel.
So for a '55 stock bell housing mounted starter, can you tell me what would be a good fictitious vehicle to look up at the auto store's computer in order to end up with a 168 tooth, 11 inch clutch?
'56 Chevy 4dr 210 327ci
'97 GMC K1500 Suburban 6.5TD
GaryC
GaryC
Loc: Pittsburgh, PA. U.S.A
Reg: 02-28-03
12-05-11 08:23 AM - Post#2165238
    In response to tmsnyder
Some additional info:
I run a stock Borg & Beck style 12" clutch setup on my 168 tooth flywheel. It fits too, not that many would want to use it.
1957 Chevrolet Bel Air coupe, 300hp 327, M20 4 speed
tmsnyder
tmsnyder
Loc: Buffalo, NY
Reg: 06-13-06
12-05-11 08:37 AM - Post#2165243
    In response to GaryC
I ended up ordering a flywheel for a 1960 chevy bel air. It's a 30 lb 168 tooth flywheel for an 11 inch clutch. And an 11 inch clutch and flat diaphragm pressure plate. I _think_ that will work with my '55 stock bell housing mounted starter and clutch fork.
Anyone know what the deal is with the raised diaphragm pressure plates vs. the flat diaphragm ones?
12-05-11 09:52 AM - Post#2165261
The conical spring diaphragm pressure plate is less likely to stick on the floor on a high rpm shift.
12-05-11 12:37 PM - Post#2165319
    In response to Rick_L
That is absolutely correct.
BUT, the cone (or raised) diaphragm pressure plate will exert more pressure on the clutch disc providing a stronger engagement. The additional pedal pressure is negligible. Personally, on all my cars, I use the cone diaphragm type pressure plate.
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
12-05-11 12:55 PM - Post#2165323
Rick and Tom -- If I want to replace my aftermarket 153-tooth, 22-lb flywheel with a stock 30-lb model, what would be a good choice without spending the money for a Hays or McLeod? Or should I just bite the bullet and get a good one? The engine rarely sees 5000 RPM.
Edit: Would I be asking for trouble with this one?
http://www.summitracing.com/parts/ZZZ-50-6516/
I can't find a real GM nodular iron flywheel that's 153T and for 2-piece main seal.
Edited by MikeB on 12-05-11 01:51 PM. Reason for edit: No reason given.
12-05-11 03:37 PM - Post#2165369
First, let me hit on a couple of basics.
ALLLLLLLLLLLL 55-85 Chevy V8 flywheels are a 100% bolt-on fit on ANY 55-85 V8 crankshaft.
ALL 168teeth flywheels are also totally interchangeable. BUUUUUUUUUT, the EARLY 168 teeth flywheels only had a bolt pattern for the 10in clutch. SOME early 168 teeth flywheels (HD, police, taxi, truck, etc) did have a bolt pattern for the 11in clutch.
Soooooooooo, here's where I'm going with this. ANY 55-85 168teeth flywheel WITH a bolt pattern for an 11in clutch will work. For your purposes, that's all you need.
Over the years, I've picked up good used 168teeth flywheels with an 11in bolt pattern at swap meets for $25-50. Some needed to be surfaced, but many did not. SOME had burn marks on the surface, but DID NOT have gouges. For those kinds of flywheels, I just bead blasted the heck out of the surface, bolted them on with a new clutch and went on down the road. That is the type of flywheel that is on my 51 Chevy, 56 Vette and 70 Chevelle. Now, I'm talking about regular driver/mild performance engines ---------------------- I'm NOT talking about hardcore, full on race engines!!!!!!!!!
Everybody and their dog tells you to get a scatter shield for a performance car with a 4sp. Well, just think about it, REALLY, how many Chevys have you read, heard, seen that have had a stock flywheel explode under regular driving conditions and kill everyone in the car???
This is an EARLY 168 teeth flywheel with the bolt pattern for ONLY a 10in clutch (the other holes are just for balance). As can be seen, even if holes were drilled and tapped for the larger 11in clutch, there is a groove machined into the flywheel surface (I have NO CLUE why the heck GM did that!!!!!!) which would prevent any benefit from installing an 11in clutch!
Here is a later 168 teeth flywheel with the bolt pattern for the 11in clutch.
Here is part of my stash of various flywheels and flex plates.
f.i.57chevynut
f.i.57chevynut
Loc: Granada Hills, CA
Reg: 03-04-09
12-06-11 12:16 AM - Post#2165527
Probably as important is the pressure plate, make sure the plate you use is forged, not cast. This happened to a guy I know. I told him to get a scatter shield, but he shined me on. Then this happened:
After this incident he changed his mind and got a scattershield, and a forged center pressure plate. The flywheel was reusable but he also bought a billet steel flywheel. This was on a 283.
Tom Ordway tom@57chevys.com If you don't drive it, why have it?
http://www.americantorque.com/page/0/139/
tmsnyder
tmsnyder
Loc: Buffalo, NY
Reg: 06-13-06
12-07-11 09:31 PM - Post#2166200
    In response to f.i.57chevynut
what rpm did that happen at? did the guy get hurt?
f.i.57chevynut
f.i.57chevynut
Reg: 03-04-09
12-08-11 10:18 PM - Post#2166577
About 6,000 and it hit his foot and he limped around with a black and blue foot, but he was lucky.
55 Shaker
Loc: north central IL.
Reg: 03-13-06
12-09-11 12:05 PM - Post#2166736
FI57 your friend was "VERY LUCKY" he didn't get hurt any worse than he did. I had an explosion in my 57 back in the early 70's. I was running a scattershield, and a chunk of flywheel still made it through the floor board, and got stuck up behind the radio. Two hours later I was still shaking, quite an experience . I put a scttershield in my 55 I got now, my feet are worth more that a few hundred bucks.
Highlander1
Highlander1
Reg: 08-19-04
12-09-11 06:42 PM - Post#2166883
    In response to 55 Shaker
I can think of things that happened to me 40 plus years ago that still cause me to shake at times. Call it luck, call it the Grace of God...
Was either your flywheel or Clutch SFI approved? In order to maintain an OE look in my 57 I plan to run both. Expensive, but like you said, what's a few hunderd bucks when it comes to your feet?
Haven't had any Strohs since Ft Knox.
55 Shaker
Reg: 03-13-06
12-09-11 07:16 PM - Post#2166896
Don, I was running a DZ code 302 engine, lots of RPM. The engine happened to come with the scattershield, or I wouldn't have bought one. The 11" flywheel clutch and pressure plate were stock GM. I was just a dumb a$$ gear head kid with no money.
I've been patronizing STROHS now for about 39 years!!!! It's getting harder to find
Brian
Execution time: 0.601 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:03 PM
