Username Post: Deck clearance        (Topic#251543)
busterrm
busterrm
Loc: Wichita Falls, Tx
Reg: 08-31-10
10-24-10 10:45 PM - Post#1994539
David and I are arguing a point lately, and I thought I would ask you guys. What is that deck clearance on a chevy 350 block that is untouched with stock pistons and rods. Oh yeah the block is 1972 block.
==== BOB ====
If I can't smoke the tires I want more!
1976 Chevy Nova
2007 Chevy 1500 1/2 ton
2008 Harley Davidson XL1200 Sportster
85Camaro
Loc: East TN
Reg: 07-14-01
10-25-10 05:04 AM - Post#1994587
    In response to busterrm
A whole lot more then you would think.
busterrm
busterrm
Reg: 08-31-10
10-25-10 05:34 AM - Post#1994603
    In response to 85Camaro
Well that really tells me a lot!
==== BOB ====
1976 Chevy Nova
rumrumm
rumrumm
Loc: Macomb, IL
Reg: 10-18-01
10-25-10 05:50 AM - Post#1994611
Around .025. All blocks are a little different so a measurement is necessary, but .025 is a reasonable ballpark figure.
Lynn
"There's no 12-step program for stupid."
383 sbc, Eagle, AFR, SRP, CompCams, Edelbrock, FiTECH. Dyno #'s: 450 hp @ 5700, 468 ft. lbs. torque @ 4300.
http://photo.net/photos/Lynn%20Johanso n
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
10-25-10 07:49 AM - Post#1994658
    In response to rumrumm
DITTO! .023-.025 has been my experience also
Edited by grumpyvette on 10-25-10 08:31 AM. Reason for edit: No reason given.
busterrm
busterrm
Reg: 08-31-10
10-25-10 07:04 PM - Post#1994990
    In response to grumpyvette
Okay, So I was right! David swears that deck on a stock block is .015, and I told him that would be after the block has been decked 10 thousandths. Now, I am can set up my Excel program to figure compression ratios. Thanks guys.
==== BOB ====
1976 Chevy Nova
10-25-10 09:32 PM - Post#1995069
you were right all right, and with a shim head gasket your piston to head clearance will be just right.
Execution time: 0.423 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:04 PM
