Username Post: 2001 5.3 110K miles, burning oil, replace engine or port        (Topic#244246)
Team Hard
Reg: 06-22-10
06-22-10 10:04 AM - Post#1934141
I am about to take on a job for a friend to fix his 2001 Silverado. I wanted to get some opinions on it first though... he has roughly 110K on the clock and as far as I know the power train is all original on the truck. Its been burning oil for about a year, but has recently progressed to the point where he claims noticeable performance decrease. At first I wanted to just take off the heads and have everything ported, install new valves, etc. and call it a day... but after reading more about the GM piston slap problem, Im curious just how bad the cylinder walls are scored and if that might be part of the issue.
That said, we are now looking at reman and lightly used engines and planning on just doing an engine swap... what do you guys think?
Bad Bowtie
Bad Bowtie
Loc: TX
Reg: 07-04-03
06-22-10 12:13 PM - Post#1934185
    In response to Team Hard
I'd pull it and tear it down to see what is happening in there. Then you know what you got to work with. If you decide to install a GM reman- you've already pulled the old motor...
Team Hard
Reg: 06-22-10
06-22-10 01:34 PM - Post#1934234
    In response to Bad Bowtie
trouble is I only have a couple days to get it done... and I am only really qualified to take it apart and put it together, I wouldnt know how good/bad the cylinders or any part of the valve train should look if I were to take it apart.
motorman
Loc: south western pa.
Reg: 01-25-00
06-22-10 02:20 PM - Post#1934262
2001 LS engines used a poor designed ring package and GM came up with a better second scraper ring and better oil ring expander. in the fix they did not even change the top ring so the engine did not have to be broken in again
retired race engine builder,former NASCAR tech inspector. new corvettes owned 1959,1962,1963,1964,1965, 1966,1997,1999,2002,2005, 2008 plus 30+ other chevy cars and trucks along the way
Edited by motorman on 06-22-10 02:22 PM. Reason for edit: No reason given.
Team Hard
Reg: 06-22-10
06-23-10 07:26 AM - Post#1934620
    In response to motorman
Ok, that is also good to know... so what year engine should I be looking for to replace his, in other words what year did they get it right?
silvervortek
Loc: Georgia USA/ west coast I...
Reg: 10-10-04
07-12-10 09:27 PM - Post#1944522
A new pcv valve has solved the oil burning in some 5.3 litre engines. is it running bad or just burning oil and by the way if i put that high milage oil in my engine it will burn 2 quarts between oil changes,tried it once. i usually use mobil 1 syn and burn half a quart between changes / been like that since new/ has 170 thou miles on it now and still pulling strong.
I have a 99 silverado, regular cab ,long bed ,was 4 wheel drive,has auto and 5.3 vortek engine. one hundred and thirty
Execution time: 0.113 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:35 PM
